![]() | Home > In Car Electronics > Towbar power issues |
I presume that it is the right indicator on the bike rack that comes on (not the vehicle)?
This is undoubtedly an earth fault of some kind, resulting in the sidelight earthing through the indicator filament (the side and indicator earths are common, ie connected together, so the 12V is in effect across both filaments in series. The indicator filament, which is brighter and therefore has a lower impedance, is lighting up much more than the sidelight, so you only see the bright one). Investigate your earths. The fault could be on the bike rack thingy or with the socket on the vehicle. You can test the rack on another vehicle, or the vehicle with another trailer or lightboard to determine which of the two is faulty. |
balmybaldwin Member Since: 17 Apr 2021 Location: Surrey Posts: 196 ![]() ![]() ![]() |
No it's the vehicle indicator that comes on. I'm yet to see light on the rack (although it was sunny so may have been v. dim)
all lights on the vehicle works normally without the rack attached. The dash light stays constant too I guess it could be the rack... will try and find someone with a tow bar tomorrow to test it |
From what you describe of its condition, it's almost certainly the socket or its wiring. I'd start by taking the socket apart and checking the connections for crud and corrosion. If the cap is broken then it needs replacing anyway but you may be able to revive it for now, at least. Then unplug the wiring harness behind the plastic cover over the back of the lights under the wheel arch and test their continuity. If it's been butchered in the past then it's easy to replace and for this I'd go for a genuine LR kit as they're very good quality. From what I can make out you have a 7 pin socket so this would be perfect:
https://www.ebay.co.uk/itm/363167801766?fi...SwxPBgtYuJ Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
The source of the problem is still most likely to be that the earth connection in the carrier.
While waiting for a neihbour to get back who has a towbar, I thought I'd have a bit more of play with multimeter
I'm getting 1.6 Ohm only between ground pin and the chassis which seems reasonably good. |
New socket turned up today. Plugged it in, and works perfectly.
Now just need to get the old socket off (2 rusty screws down, 3rd is being a pita) |
