Home > Puma (Tdci) > Output shaft failure, Forum Survey
Page 15 of 35 <123 ... 141516 ... 333435>
Bluest
Hi think Nige has done a Sterling job with this video on this subject.
 2007 110 TDCi Station Wagon XS
Post #907375 11th Jun 2021 10:34am
DSC-off
Yes, Nigel's done a good summary of the situation.
Great to see his method of measuring the alignment. Thumbs Up
Of course, it's all out of the vehicle and partially disassembled to do it, but it can done.
Interesting to see a 'good' transmission assembly was showing a 12 thou' run out. That is a 6 thou' offset between the gearbox and transfer box, or 0.15mm.
Now there's a possibility of measuring the offset and relating that to the failure milage, but I'm not hopeful that anyone else will go to the trouble of doing it. Wink
Post #907423 11th Jun 2021 3:57pm
DSC-off
- Perhaps, if you had a vehicle that is badly misaligned, you could set it up on the bolts and clock it in true, then remachine one set of dowel holes to keep it that way. Very Happy
Post #907424 11th Jun 2021 4:12pm
Julie
France 2012 Defender 110 Puma 2.2 SW Keswick Green
Yes, that's a nice vidéo. Of course, everbody knows that the grease cannot be confined inside the spline with a rubber seal.
It must be renewed -
Unfortunately this cannot be done easily (because one cannot access that spline within 5...10 min or so.
That's why I cannot accept Nige saying the output shaft is "good design". Land Rover engineered it badly. Neutral
I appreciate the solutions trying to help us out (LOF, Ashcroft) and had the Ashcroft kit installed.
And I'm hoping that in near future somebody comes up with the perfect solution !
Post #907437 11th Jun 2021 5:36pm
Dinnu
Great video by Nigel.
Could have checked for angular misalignment by placing the dial gauge on the mating face of the tcase. But parallel misalignment is probably more at play.
Wonder if the same measurement can be done with the tcase in situé, by removing the tcase input gear, mounting the dial gauge on the intermediate shaft itslef, and use the lt230 input gear rear opening as reference. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #907503 12th Jun 2021 6:47am
Dinnu wrote:
... Wonder if the same measurement can be done with the tcase in situé, by removing the tcase input gear, mounting the dial gauge on the intermediate shaft itslef, and use the lt230 input gear rear opening as reference. ...
I don't see why not, but I'd try to use the rear bearing outer race rather than the transfer box opening. It might even be possible to check with reference to both front and rear bearing races.
One try at the next opportunity I think.
Post #907517 12th Jun 2021 9:07am
Dinnu
Have a clutch and an intermediate shaft replacement planned for a 2.4... so will try to measure it out. I think if can measure both input gear races then can determine not only parallel misalignment, but also angular misalignment. Thumbs Up
Edit, pity that have no history of the intermediate shaft for that vehicle. The odometer stands at 150kmiles. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #907554 12th Jun 2021 2:46pm
Angus_Beef
Norway 2015 Defender 110 Puma 2.2 SW Corris Grey
1, 2015
2, 2.2
3, No
4, First shaft replaced at 54'000 miles as preventative maintenance. Had some life left in it but grease had dried away. Replaced with LOF one piece. Roaming around 🇳🇴🇨🇭
Post #912452 15th Jul 2021 7:16am
CallumB
United Kingdom 2013 Defender 110 Puma 2.2 USW Corris Grey
1, 2007
2, 2.4
3, N
4, Unknown mileage but shaft previously replaced with std LR one. Replacement had signs of wear and no grease. Now replaced with Ashcroft unit as precautionary.
5, Per 4 for first failure, but yes now.
6, 63,100 current mileage (Ashcroft fitted 62,619).
Post #912467 15th Jul 2021 9:02am
piechipsandpeas
Australia 2013 Defender 110 Puma 2.2 SW Indus Silver
1. 2013
2. 2.2
3. Yes, original shaft
4. No failure, 69,000 miles (111,000km) but shaft is very worn. Shaft not secured by locking ring and fell out when transfer box removed. Some evidence of lubrication on splines but not sure if this was grease from factory or slight leak from gearbox rear seal.
5. Fitted LOF 1 piece shaft.
All back together with new LOF Powerspec clutch and no backlash whatsover Very Happy . Now have to learn a new driving style to compensate. Should have done this long ago.
Post #924507 5th Oct 2021 3:58am
Interesting to see Richard Hammond having the issue but putting it down to the Bowler Stage 2 kit fitted:
https://www.facebook.com/drivetribe/videos/579677569974536/
Post #928438 4th Nov 2021 8:11am
Gleo
Isle Of Man
LOF extreme output shaft all the way Wink
Would be great if Hammond stripped it, and filmed
the retrofit to an LOF on his channel, and feels all of our pain whilst doing so Smile
Post #928447 4th Nov 2021 9:14am
jpboost
United Kingdom 2014 Defender 110 Puma 2.2 SW Keswick Green
Surely this is just a bit of journalistic embellishment for the sake of a feature? If the shaft fails due to fretting, and loads of us are running similar power & torque on our TDCI's, I can't believe he's somehow stripping the splines on a regular basis?
I would also think Bowler are well aware of the Ashcroft and LOF solutions in this space.
While happy to point it out, in general I don't have huge problem with this sort of story making in shows 'like' TopGear. The are entertainment shows after all, and the technical detail isn't allowed to get in the way of a good story....
Nice car though, I might have a look at some of his shows just to see his nice 110 Smile
Post #928452 4th Nov 2021 10:03am
Well if Bowler have a social media manager, then maybe they should get on to him and get the real facts out there.
Of course, that might now be difficult with the JLR ownership - as who are they going to point the finger at?
Post #928453 4th Nov 2021 10:13am
Gleo
Isle Of Man
Has anyone's fuel efficiency improved since upgrading to LOF
Has anyone noticed a marked improvement in their fuel efficiency since upgrading to a new single piece LOF Extreme Output shaft?
Since having upgraded to a LOF power clutch and an LOF Extreme output shaft I have consistently noticed that my Puma 90 is getting an extra 30-40km per tank. Apart from gearbox and transfer box oil changes at the same time, I can't explain why my fuel efficiency has improved. Has anyone else noticed this having done the LOF upgrades?
Post #928456 4th Nov 2021 10:30am
