![]() | Home > Tdi > Possible 300 Tdi Head. |
sako243 Member Since: 08 Jul 2014 Location: Wales Posts: 1248 ![]() ![]() ![]() |
Which decade do you want it in? Ed
82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11062 ![]() ![]() |
![]() Will try this one to start with ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
Well if you want it give me a shout. Ed
Oi - I have two spare, they're conveniently in smaller pieces for reduced shipping costs.
I do have one intact spare crank but it is a V8 one from Nige intended for a table... ![]() 82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
Will do and thank you again Ed ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
I Like Old Skool Member Since: 23 Feb 2015 Location: Manchester Posts: 869 ![]() ![]() ![]() |
P gasket! Mine (300tdi)was using water randomly without trace recently and eventually traced to the P gasket.
It's a poor design fault, mine was leaking when I got it over 5 yrs ago and started again recently so this time I replaced the metal gasket with a diy cut card gasket and so far so good. Worth trying before you start ripping heads off? |
Sorry a bit late with the reply, but it's not the P gasket as she is consistently drinking water more now and it seems to be the same symptoms as when the original head cracked in three places
So the outcome to this thread is on page 51, here
https://www.defender2.net/forum/topic57447.html Thank you for all your reply's, very much appreciated ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 5353 ![]() ![]() |
i would look at sending the head away to checked etc, to see why its failed.
![]() In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
I was going to send it away to be tested but my indy showed what he suspected and took the exhaust valve out as it had some rusty water marks around the edge of it and he found a crack in the head by the shaft were the valve stem goes through
My rover metros vvc engine started to blow from the exhaust side of the head gasket, and that was down to, who ever assembled the head back on the car, They had decided to use a early generation head gasket. They had spent a few quid on getting the head ported and polished but decided skimp on that. I recon to this day, it was just a odd ball special, that was built up to get a car on the road. Because when me and my dad, did the head gasket on it, we found one of the pistons looking very black.
![]() ![]() In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
foxhound Member Since: 02 Mar 2013 Location: United Kingdom Posts: 363 ![]() ![]() ![]() |
i've just replaced my head with a turner. The old one will need lapping but it's for sale if anyone wants it. 110 Defender 300tdi & Penman trailer with ally exped top and roof tent
