![]() | Home > Td5 > New, modern, rear view mirror with back up camera |
wyvern Member Since: 14 Dec 2009 Location: Cornwall Posts: 2151 ![]() ![]() ![]() |
We also have a mirror with built in forward and rear dash cam which works well for us - not the most expensive but does the job!
Ive added it directly to the battery as it works better that way, and added a dedicated on/off switch to the device which is nice as I can leave it on when parked in supermarkets etc... https://www.amazon.co.uk/VersionJansite-Re...9986129-9/ Love your mounting bracket ! ![]() Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 ![]() |
gumdrop Member Since: 16 Jan 2010 Location: North Yorkshire Posts: 127 ![]() ![]() |
Looks neat .. do you have the details to see if its available in the UK ? How did you go about wiring up - assume up the sides of the windscreen and across/under head lining ? Cheers
Simon ------------------------- 50th D90 - my toy! Freelander SE Td4 3 door - local run around 1958 Series 1- Rag top! |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 993 ![]() ![]() ![]() |
Aliexpress is where I picked it up so I am sure you can get there. I’ll look for the exact model. Yes I ran the wires down the A pillar and then back up and ran it along the gunnel to the rear and dropped it out from the rear window panels to the rear tail light and then out through the grommet to the camera.
![]() This can also be left on and has gyro on board to start recording on impact and or vibration sensors to do the same thing. 👍🏻 Found it! https://www.aliexpress.com/item/3236776305...4c4dt6uNGU 2020 range Rover Mk IV Autobiography PHEV 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3612 ![]() ![]() ![]() |
I saw this rear view mirror mentioned by the OP when I was looking for one. I should have bought this one as I think it doubles as a dash DVR. Would have already paid itself 😩. I went for a much cheaper version.
The problem I have with mine is its physical size. When my SWMO lowers the sunshade (she still hopes that there is a mirror), she knocks the rear view mirror/monitor out of its adjustment.... partly because the sunshades are gigantic, and partly because the new rear view mirror is humongous. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Yup its much larger I can see both people sitting in the two seats behind me. And yes the passenger sun visor hits the mirror. 🤷♂️ For it not to do that, it would have to sit a couple inches lower which I was not prepared to do.
Also I just noticed it has doubled in price since I picked it up a few months back ![]() 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
I placed a picture of my setup on this thread. https://www.defender2.net/forum/topic78756.html
You can also see that only 30% of the mirror is really rear view. The rest is the view of the seats ![]() 2012 90 CSW, 2.2TDCI, Santorini Black |
Where’d you get the bracket? Did you pull the OEM one out and insert it into the new mirror? 2020 range Rover Mk IV Autobiography PHEV
It simply clips onto the oem mirror. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
carpetsauce Member Since: 19 Mar 2021 Location: Essex Posts: 58 ![]() ![]() |
Hi 4RF RDS,
Can you give some detail on the mounting bracket you made for the rear view camera please? |
couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1830 ![]() ![]() ![]() |
I have the same problem, both sun visors hit the mirror. Plus, unless it’s a dull day it’s hard to see the camera image as the screen isn’t that bright. I’m about to ditch it and try a radio with built in screen for viewing the camera. Cheers Simon |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6028 ![]() ![]() ![]() |
I went with a radio (single DIN) with reverse camera mounted off the rear high level brake light 1999 Defender TD5 110
^^^ yes, agree there.
Still hoping that someday I can justify this: https://parts.jaguarlandroverclassic.com/l...black.html 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
nosnibod Member Since: 15 Aug 2007 Location: West Midlands Posts: 370 ![]() ![]() ![]() |
No reverse camera input on those. Amazing considering the price… Dave
Green Goddess - 1998 Defender 110 300tdi |
I ordered one like this, for the price it's worth a go.
https://gbr.grandado.com/products/radio-1-...OMEALw_wcB Cheers Simon |
