![]() | Home > Technical > Rear anti roll bar link - bolt and bush disappeared x2 |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6218 ![]() ![]() ![]() |
Funnily enough, I changed the lower rubbers on the front of my 110 a while back. fitted a new bolt (the old one had a lot of wear in it) but used the original nut.
Thought i'd done it up nice and tight, although it's awkward on mine as i've got a southdown lower axle guard. A while later I thought my handling felt a little odd, looked underneath and the bolt had come out. rubbers & nut gone AWOL, luckily the bolt was rattling around in the axle guard. new nut, fitted F-tight, seems to be OK now. |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2684 ![]() ![]() ![]() |
The one side fell out when we went to Land Rover Experience with the brand new vehicle. Looks like they didn't tighten it properly at the factory - along with a number of other things. ![]() 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Who needs anti roll bars?? My Camel Dicovery didn't have them. OK it cornered like a 2CV what sometimes scared my passengers. And it's better off-road without them.
![]() 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2509 ![]() ![]() ![]() |
Not much of a difference with/out the rear ARB in my 110". Though, do not know when loaded or with a roof rack. Puma 110" SW
I don't find that the AR bars on my 110 restrict axle travel much at all (although it is heavy, so i think the extra weight will force axle movement off road) but it handles a dream on road.
plus plus situation really! |
SteveS Member Since: 05 Oct 2010 Location: Devon & Berkshire Posts: 388 ![]() ![]() ![]() |
With HD springs on the rear and a 2" lift with quite a bit of weight on the roof - a roof tent, side awning and heavy duty rack - so operational anti roll bar would have been useful - having said that it appears to have reasonable articulation over the rough stuff. But with lockers front and rear I'm not bothered if it pokes a wheel in the air or doesn't drop into a hole.
