![]() | Home > Technical > Nato 12 pin to civvy 7 pin |
v8bob Member Since: 14 Mar 2018 Location: Midlands Posts: 344 ![]() ![]() ![]() |
I believe Santana were made under license in Spain. So if your one is from Solihull, then not a Santana. |
Username Member Since: 08 Aug 2021 Location: Ludlow Posts: 1 ![]() ![]() ![]() |
Hi Blackwolf. I bought a kit like this, fitted easily to my previous tithonous ex mil 110. Replaced that with a wolf 110 last year, but can't fit the reinforcing piece, because the bolt holes on the underside of the rear cross member are missing. I can't just bolt the ladder directly to the rear cross member, using the 4 holes for the pintle, because that raises the height, so the braces foul on the fuel tank. Any ideas? I'm th bk ng about just welding the reinforcing piece directly to the rear cross member. Cheers, Oli |
Lops Member Since: 18 Jun 2019 Location: Worcestershire Posts: 7 ![]() ![]() ![]() |
![]() Click image to enlarge Hello all I've looked through this thread and I have a Penman with NATO twelve pin and need to connect it to the existing 7 pin on my Puma, I think I've worked out the wiring just a couple of questions will this wiring still allow the front lights on the trailer to work, I'm assuming the are wired in with rear lights and does the convoy light influence any thing else? not worried about the permanent live as I have a heavy duty Anderson plug to connect to supply the powered stuff. hope the pic is visible any help/advice is appreciated |
Military rear crossmembers are often quite different from civvy ones, which is why the Dixon Bate kit doesn't bolt straight on, unfortunately. If you have the means to weld on the reinforcing piece then that's a good solution. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Yes, the front marker lights are wired in with the rear lights. The convoy light doesn't influence anything. It's actually the other way around in that the convoy light switch in the towing vehicle that influences the convoy light. Basically, if you don't apply power to it's specific wire then it won't come on. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
cheers thanks for that
Intercept Member Since: 27 Feb 2017 Location: Suffolk Posts: 587 ![]() ![]() ![]() |
I was lucky enough to get one of the D&DE adaptors secondhand (but unused) a while back for a good price. It works well and allows me to use my Sankey with the 110 and 101 but I wouldn't pay the full £102 - I'd do it properly and fit a NATO socket to the 110. However - even at that price there seems to be no shortage of demand because every batch of adaptors sells out very quickly. The 12/24 voltage issue was solved invisibly on the Sankey via some lamps from Classic Car LEDs. |
