Home > Off Topic > Disco 5 |
BenB8man Member Since: 22 Mar 2017 Location: Norfolk Posts: 427 |
I was hoping that the oil dilution and crank issues were only on the older engines?
20th May 2021 1:52pm |
jim4244 Member Since: 13 Apr 2014 Location: Bedfordshire Posts: 645 |
Don’t forget the failing windscreen seals which let water leak behind the instrument panel……..🧐
Jim |
20th May 2021 1:55pm |
Huttopia Member Since: 23 Feb 2016 Location: West Midlands Posts: 1968 |
As ever it is hard to get a clear picture based on some Googling. How many vehicles actually suffered from the crank issue vs number sold. Ditto genuine oil dilution vs over sensitive sensor (and subsequent recalibration). I've got a TD6 coming which I think is the old D4 engine with the odd tweak. Fingers crossed!
20th May 2021 1:59pm |
Thanks Jim! Hopefully that has been sorted out by now. |
20th May 2021 5:03pm |
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3259 |
I traded my 2017 TD6 in after 10 months as it was suffering oil dilution, from what I’ve been told the next owners had to get a new engine. Not sure if it was related to oil dilution or a separate issue. Other than that it was a nice enough motor.
Click image to enlarge 24MY 90 D250 HSE, Tasman Blue |
20th May 2021 10:42pm |
I think if there are issues along those lines I’ll get the oil independently tested to understand whether it is dilution or the report of dilution. Obviously hoping not to have to worry about that sort of thing!
Trying to work out if my TransK9 box from the D3 and D4 (took up exactly half the boot) will fit in the D5. 🤔 |
20th May 2021 10:45pm |
Not sure, I think the slope of the rear screen may be an issue. 24MY 90 D250 HSE, Tasman Blue
20th May 2021 10:52pm |
