Home > Puma (Tdci) > Drive belt - life expectancy
Anyone know the life expectancy of the engine ancilliaries drive belt on the Puma, or have recommendations for the mileage at which it should be changed?
I noticed a new albeit faint squeak from my engine which happens once per complete revolution of the belt, and wondered if it was a warning sign. My belt appears to be the original and has done c.85k miles; it looks in good condition and hasn't got oily or contaminated.
Failure on the road would be inconvenient since it drives just about everything on the Puma!
Thanks.
Post #90371 21st Sep 2011 2:33pm
Grockle
does it show signs of wear ? 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #90408 21st Sep 2011 4:21pm
Not that I can see.
Post #90411 21st Sep 2011 4:25pm
Grockle
keep an eye out for the wire in the belt starting to show then change it 2.4 90 XS
Post #90413 21st Sep 2011 4:28pm
parktag
France 2008 Defender 130 Puma 2.4 HCPU Zermatt Silver
On my check sheet it says 200k km which is about 120k miles so if it looks ok it probably is. 130 crew cab
98 V8 Disco
Post #90431 21st Sep 2011 4:57pm
Fifth Horseman
Yes, UK service sheet shows replace drive belt at 120K miles
Post #90455 21st Sep 2011 7:26pm
Thank you!
Post #90838 23rd Sep 2011 1:56pm
RED-DOT
If in doubt change it as it only takes 30 minutes but draw a diagram of all the toothed gears first as it will help with re-fitting the correct way. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #90840 23rd Sep 2011 2:23pm
