![]() | Home > Puma (Tdci) > Drive belt - life expectancy |
does it show signs of wear ? 2.4 90 XS
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17878 ![]() ![]() ![]() |
Not that I can see.
keep an eye out for the wire in the belt starting to show then change it 2.4 90 XS
parktag Member Since: 30 Sep 2008 Location: Brittany Posts: 366 ![]() ![]() ![]() |
On my check sheet it says 200k km which is about 120k miles so if it looks ok it probably is. 130 crew cab
98 V8 Disco |
Fifth Horseman Member Since: 08 Mar 2011 Location: Lanarkshire Posts: 338 ![]() ![]() ![]() |
Yes, UK service sheet shows replace drive belt at 120K miles
Thank you!
RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363 ![]() ![]() |
If in doubt change it as it only takes 30 minutes but draw a diagram of all the toothed gears first as it will help with re-fitting the correct way. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
