Home > Maintenance & Modifications > Preferred Rear Dif Oil
ChrisDefender
Hi all,
As per the title, is there a general favourite oil used for the rear dif? I have tried a search on here but cannot find a recent definitive answer.
Its for a 2.4 90HT.
I am leaning towards this one?
Motul Gear 300 75W-90 Fully Synthetic Car Gearbox & Diff Oil
https://www.opieoils.co.uk/p-899-motul-gea...Case%20Oil
Many thanks in advance.
Post #903585 17th May 2021 5:14pm
Bluest
Motul Gear 300 is a top of the range synthetic gear oil. It is fine for the diff, but I would say it is overkill and very expensive. I use Motul Gear HD in my diffs and they haven't exploded yet Laughing 2007 110 TDCi Station Wagon XS
Post #903588 17th May 2021 5:24pm
ChrisDefender
Hi mate,
OK, thank you, good to know. Thumbs Up
Post #903594 17th May 2021 5:34pm
Ianh
I use Castrol Axle 'EPX' for the Diffs..
i would say most diff oils from a decent manufacturer will perform well in normal use. So the best way to care for diffs is to fit magnetic drain plugs as they are not expensive, check breathers are free and levels are maintained, check after going through deep water (for water ingress) and do regular oil changes rather than going for the most expensive diff oil.
Sticky on gearbox engine and diff oils for 2.4 and 2.2 https://www.defender2.net/forum/topic8707.html
Post #903602 17th May 2021 6:10pm
ChrisDefender
Thumbs Up Many thanks.
Post #903618 17th May 2021 7:18pm
Gloucesternige
United Kingdom 2011 Defender 90 Puma 2.4 HT Keswick Green
I am in a bit of a quandry.. my 2011 Puma calls for synthetic oils in Diff and TC, but i have Ashlocker and ATB's in mine. Ashcroft recommend mineral oils.
So, what is the best and safest mineral oil to use in the axles and TC? I have heard of GL5 causing issues in older designs? Nige
Check out my You Tube channel
https://www.youtube.com/c/Defender90KeswickNigelsLandRoverchannel
Post #915309 3rd Aug 2021 2:06pm
Co1
I think you can use either, but with slightly different consistencies. From their website: “ either mineral EP80/90 or synthetic EP75W90”.
Post #915312 3rd Aug 2021 2:31pm
LR90XS2011
I spoke to Ashcroft as I also have ATBs they said Castrol Axle EPX 80W-90 Mineral Car Gearbox Oil GL5 would be just fine DEFENDER 90 TDCI XS,
Post #915360 3rd Aug 2021 8:53pm
