Home > Technical > Towbar extender for bike rack |
B4Lamb Member Since: 21 Mar 2015 Location: Abergavenny, Wales Posts: 233 |
No need to weld nuts on a Dixon Bate, it's thick enough to drill and tap 2 M8 holes either side then fit two M8 screws with a lock nut to stop it rocking on the adjusting pin. "You are never to old to learn something new" |
12th May 2021 5:35pm |
MussEd Member Since: 20 Feb 2013 Location: East Lothian Posts: 345 |
Click image to enlarge Click image to enlarge For those after a simple extension to bring out the towbar far enough to clear the rear spare I found this on Amazon. It’s obviously no use if you still want to tow when bike rack isn’t in use…£24 |
21st Jun 2021 8:57am |
sjc501 Member Since: 05 Feb 2018 Location: Glasgow Posts: 148 |
I found this on the 4x4 overlander site Nakatanenga Cycle Carrier Adapter .Cost 185 but you can attach and remove when required . I need something to carry 2/3 Heavy downhill bikes currently I'm using a Dave cooper set up designed for a motorbike but can be removed quickly
25th Jun 2021 5:24pm |
Rugratnav Member Since: 30 Sep 2017 Location: The wrong side of the Pennines Posts: 9 |
Hi Leeroy, I’m having the same issue as everyone else! How far out from the rear X-member does this put the tow ball? Does it clear the spare wheel? Thanks John In Yorkshire, but near enough to the Lancashire border! |
24th Jan 2022 12:29am |
Vitesse Member Since: 21 Mar 2014 Location: Sussex Posts: 372 |
I fitted this extension today. Haven’t used it yet but it seems v strong It bolts on to the standard tow ball and extends by 250 mm
Click image to enlarge 2015 90 XS Santorini Black |
7th Oct 2022 7:02pm |
That's a lot of cantilever on the tow ball but okay for a bike rack I suppose. "You are never to old to learn something new"
7th Oct 2022 9:34pm |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3612 |
I too would be worried about the load imposed on the 2 bolts with those simple bolts on extensions, fine for a bike rake put perhaps not so good with 100kg vertical towbar load from a caravan, (or more with some trailers). DEFENDER 90 TDCI XS,
8th Oct 2022 6:15am |
Yep. Totally agree. The part is specifically designed for bike carrier and 80kg load. No more than that and certainly not for normal towing. 2015 90 XS Santorini Black
8th Oct 2022 9:25am |
It explicitly states not to be used for towing - purely for the bike rack |
21st Oct 2022 2:27pm |
pmason1973 Member Since: 28 Feb 2022 Location: London Posts: 4 |
Hi Vitesse. Has this help up ok? I'm thinking of doing the same thing but with a bigger rack (https://pbr.co.uk/products/wheel-support-bike-rack) and concerned about the leverage on the first tow ball. Many thanks, Paul. |
6th Jul 2023 1:15pm |
Vitesse, one more question. Is it the 200mm or the 250mm length extender? Thanks |
6th Jul 2023 2:47pm |
