Home > For Sale & Wanted > [Wanted] Dixon bate slider base
Likeomg
Hello
Need a Dixon bate "backing plate" / tow bar
something ideally that needs powder coating as my plan is to cut it up - I just re powder coated the one I took off before fitting a NAS so don't fancy chopping it up.
Only this piece, no braces / slider / pins etc.
Post #902168 9th May 2021 3:25pm
Retroanaconda
Does it need to be that exact type? I have a spare one but it’s got the larger bolt holes in a continuous plate at the bottom rather than the two separate tabs like that one (which is upside down!).
Post #902216 9th May 2021 6:37pm
Likeomg
christ, didnt even realise It was upside down just pulled a pic from google quick,
I'll edit that as it hurts my eyes. Rolling with laughter
Post #902222 9th May 2021 6:55pm
Likeomg
Yes, this type (same as what I've just had coated)
im guessing the pic I posted is a earlier type, im only really interested in the area where the 4 main bolt holes are, I will be cutting the rest away just to leave a mounting plate on my NAS step for my bike rack..
Where abouts up north are you and what do you want for it?
Post #902224 9th May 2021 7:00pm
Retroanaconda
This is what I have:
I’ll send you a PM.
Post #902252 9th May 2021 9:02pm
Shorter racks that fit the DIN 4-bolt hitch mounting (i.e., the four holes on an NAS step) are available and often turn up on ebay. I have bought several over the years to use on 2" receiver fittings. This sort of thing...
Post #902257 9th May 2021 9:07pm
Likeomg
yeah, thats ideally what I need, but can easily cut down something thats seen better days also..
Did I overlook the fact what I / anaconda have posted won't match up to the 4 bolts on the NAS I have or will this be fine?
they are all m16 with 90mm x 45mm spacing?
Post #902265 9th May 2021 9:40pm
The standard (BS Au 114a) two-bolt coupling dimensions are two holes 16.5mm diameter (or 5/8") at 90mm centres.
The standard (BS Au24) four-bolt coupling dimensions are four holes 13.5mm diameter (or 33/64") at 85.75mm x 44.45mm (or if you prefer 3.3/8" x 1.3/4") centres.
I've never owned an NAS rear step so I don't know for sure what they take, but I would expect that it would be the latter.
DB sliders are usually drilled with four 16mm holes at 90mm x 44.45mm centres, since this allows either coupling type to be bolted to them.
Post #902271 9th May 2021 10:47pm
