![]() | Home > For Sale & Wanted > [Wanted] Dixon bate slider base |
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2677 ![]() ![]() |
Hello
Need a Dixon bate "backing plate" / tow bar something ideally that needs powder coating as my plan is to cut it up - I just re powder coated the one I took off before fitting a NAS so don't fancy chopping it up. Only this piece, no braces / slider / pins etc. ![]() Click image to enlarge Last edited by Likeomg on 9th May 2021 7:02pm. Edited 1 time in total |
christ, didnt even realise It was upside down just pulled a pic from google quick,
I'll edit that as it hurts my eyes. ![]() Last edited by Likeomg on 9th May 2021 7:01pm. Edited 1 time in total |
Yes, this type (same as what I've just had coated)
im guessing the pic I posted is a earlier type, im only really interested in the area where the 4 main bolt holes are, I will be cutting the rest away just to leave a mounting plate on my NAS step for my bike rack.. Where abouts up north are you and what do you want for it? |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2767 ![]() ![]() |
This is what I have:
![]() Click image to enlarge I’ll send you a PM. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17936 ![]() ![]() ![]() |
Shorter racks that fit the DIN 4-bolt hitch mounting (i.e., the four holes on an NAS step) are available and often turn up on ebay. I have bought several over the years to use on 2" receiver fittings. This sort of thing...
yeah, thats ideally what I need, but can easily cut down something thats seen better days also..
Did I overlook the fact what I / anaconda have posted won't match up to the 4 bolts on the NAS I have or will this be fine? they are all m16 with 90mm x 45mm spacing? |
The standard (BS Au 114a) two-bolt coupling dimensions are two holes 16.5mm diameter (or 5/8") at 90mm centres.
The standard (BS Au24) four-bolt coupling dimensions are four holes 13.5mm diameter (or 33/64") at 85.75mm x 44.45mm (or if you prefer 3.3/8" x 1.3/4") centres. I've never owned an NAS rear step so I don't know for sure what they take, but I would expect that it would be the latter. DB sliders are usually drilled with four 16mm holes at 90mm x 44.45mm centres, since this allows either coupling type to be bolted to them. |
