Home > For Sale & Wanted > [Wanted] Bike rack
Likeomg
[Wanted] Bike rack
Who has what hidden away unused?
Looking ideally for a Thule VeloSpace but will consider options...
Will buy online if nothing turns up,
Cheers,
Post #902163 9th May 2021 2:52pm
jonny
I have a Pendle 4 bike rack in the garage, built like a tank and works OK with a rear door mounted spare (although requires some fiddling if you want to get 4 on with a spare on the back).
It's the older (much less orange!) version of the W4 rack: https://pbr.co.uk/products/wheel-support-rack
Post #902182 9th May 2021 4:18pm
scotsstag
Scotland 2004 Defender 90 Td5 CSW Rutland Red
Got one of these if you're interested.
Plate bolts behind spare wheel and stays in place, rack is then fitted/removed in seconds as and when req'd.
You can even slip it into the back of the Landy while you're on your ride.
 04' 90 Td5 CSW..
Post #902185 9th May 2021 4:39pm
Likeomg
Hi Pendle is a option although would prefer something more Thule type.
Wheel / door mounts are out, I've already got a heavy 18" 285 tire on the back door, don't fancy a rack then a few 23kg E bikes.
Cheers.
Post #902192 9th May 2021 5:10pm
My Pendle has lasted 20 years maybe. I have normal and fat bike adaptors for it.
It’s a 4 bike, but only use 2 slots...
Actually used it today!!
 QRZ 2e0vpf
Post #902196 9th May 2021 5:43pm
scotsstag
Lovely set up all round Thumbs Up 04' 90 Td5 CSW..
Post #902198 9th May 2021 5:47pm
Likeomg
How would it fit a XL DH bike etc?
I welded this up a few year ago but it was designed around the Ibis I had at the time... even tho it was a XL bikes have got longer and longer...
Seen here again a few years later now sporting its lovely orange powder coating
I have also enquired for a Dixon bate to make something like this, but the orange rack despite being totally solid I don't think is long enough for new gen of bikes.
Post #902201 9th May 2021 5:54pm
Likeomg
The orange rack is welded directly to a Dixon bate slider as seen here, so I could bolt the plate onto my Nas and run it but again... will the E bike fit?
Guess I could cut and modify but im still a little Evil or Very Mad after paying close to £100 for it to be powder coated orange.. (not my colour choice, although new frame is orange? Shocked )
Post #902204 9th May 2021 5:56pm
Custom may be an idea.
The wheel supports slide in and out on a Pendle, it can go as short as a bmx, but i’ve never tried a DH rig with big rake tbh. QRZ 2e0vpf
Post #902228 9th May 2021 7:19pm
Likeomg
im thinking now to modify this or build v2...
it was just a bit heavy and awkward to attach, so if I lengthen it for the new gen of bikes and also somehow split it into 2 parts with a sleeve I can make it easier to attach.
Post #902233 9th May 2021 7:29pm
