Home > Puma (Tdci) > How much in a nipple?
Page 2 of 2 <12
bob neville
mick wrote:
Dealer told me there are no nipples on the front propshaft Neutral
Mick
2009 110 has one in the centre of each UJ - at least mine does ! Rears are easy to see and use, fronts are a real pain !
Bob
Post #90075 19th Sep 2011 10:27pm
MK
Actually the flexible makes it more dificult because sometimes you need to push against the nipple to get the grease in. OE nipples are a PIA. I changed mine for proper longer ones. I can suggest Mobil XHP222 grease (NGLI2 - blue), very sticky and water resistant.
As mentioned, the sliding joint just needs a few shots. Do not fill until the rubber swells (manual states). Puma 110" SW
Post #90083 20th Sep 2011 2:49am
stevie d
United Kingdom 2003 Defender 90 Td5 SW Alpine White
From a point made earlier the front swivels require one shot grease/ I use same grease as propshafts. These I check every 6k when oil is changed, mine never seem to need much.
When greasing propshafts I always jack up a wheel so the props can be turned, front and rear.
Steve Thumbs Up Defender 90 TD5 Station Wagon
Discovery 3 HSE
BMW 330i Coupe
Post #90109 20th Sep 2011 9:39am
MK
Swivels require NGLI 00 grade, whereas UJs, NGLI 2, and of different composition. Puma 110" SW
Post #90125 20th Sep 2011 10:42am
jst
mines got them. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #91325 26th Sep 2011 7:20am
Surrey Rover
Rossy mentioned this earlier, why should you not pump until the excess grease comes out?
I have never greased my LR but always do my trailers and mini digger with the pump till it's visible rule. I have yet to damage anything or suffer a problem but if it's not a good thing to do it would be nice to know why. Nick
2.2 110 Tipper
Post #91331 26th Sep 2011 8:06am
Paul_1978
England 2004 Defender 90 Td5 CSW Zermatt Silver
In some applications if you pump away untill you see grease coming out it can knacker the seals, allowing crap to enter.
We have bearings on site where too much grease can be more of a problem than none!
Post #91334 26th Sep 2011 8:35am
Merlin
FYI my 2008 has grease nipple on the front of the front UJ. I was told to grease a UJ until you heard a crack, as the old grease was forced out. Then you stopped greasing.
Merlin
Post #91348 26th Sep 2011 10:30am
NinetyTD4
Wales 2012 Defender 90 Other SW Keswick Green
Took these two thingies
http://www.amazon.de/gp/product/B001ILAEWY/ref=oss_product
http://www.amazon.de/gp/product/B001ILF3O8/ref=oss_product
and got grease into every 5.000 km, but that is for frequent offroad use. Ordinarily greasing at maintenance by the dealer should be ok for road use. Never forget: cars have owner, Landrover have field service personnel.
Post #91368 26th Sep 2011 1:37pm
ZeDefender
Thanks - I eBay.de something similar but had to file down the sides to get it into the UJs (actually I did it twice because I cooked the rubber in the first one with my angle-grinder (Winkelschleifer - love that word Smile )
Post #91378 26th Sep 2011 3:02pm
Page 2 of 2 <12
