Home > Puma (Tdci) > How much in a nipple?
ZeDefender
... Pfnaaah
But seriously, for a newbie Embarassed, how much grease should go into a propshaft end and how often? I need to buy a grease gun (in Germany) - any specific type?
Cheers,
Matt
Post #89999 19th Sep 2011 4:28pm
roel
Netherlands 2003 Defender 90 Td5 PU Caledonian Blue
Probably some people here won't agree but this is what I do with a Landy that is used mainly on the road and sometimes off-road:
I give the nipple's Whistle off the sliding parts a few pumps at every service intervall and the U-joints till you feel resistance or grease starts coming out.
I do the same before going off-road expecially if I expect water or mud to be present. And after cleaning the landy I do the same again.
I grease the nipples before and after off-roading, before to prevent water getting in and after to push water out again.
The standard farmers grease gun will work but an flexible hose on the end makes work easier. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001)
1997 Camel Trophy Discovery 300TDI (2001-2009)
2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts.
2003 90 Td5 (2009-now)
Post #90003 19th Sep 2011 4:46pm
Woody3
United Kingdom 1989 Defender 90 200 Tdi HT Bronze Green
Anything like this:
http://www.machinemart.co.uk/shop/product/...SRC-grease
also get the flexible hose with it.
I do my propshafts every 3000 miles. I squeeze in as much grease as possible until grease starts coming back out. I then wipe away the excess grease.
Thumbs Up
Post #90005 19th Sep 2011 4:49pm
ZeDefender
Thanks - apart from the props, where are the other important greasing points?
Cheers,
Matt
Post #90006 19th Sep 2011 4:50pm
ZeDefender
Woody3 wrote:
Anything like this:
Thumbs Up
Mine are way overdue then Confused
Post #90007 19th Sep 2011 4:51pm
Woody3
I've had a quick check in Haynes Manual and it states every 12,000 miles Thumbs Up
Post #90016 19th Sep 2011 5:08pm
roel
If you use it only on-road 12000 miles is OK. A little low on grease is on the road not a problem but off-road water might get is and water is often dirty. So That's why I prefer my before and after off-roading approuch. Roel
Post #90018 19th Sep 2011 5:13pm
bob neville
Slightly Off Topic
How do you attach a grease gun to the front UJ of the front propshaft - onto the only nipple almost dead centre ?
Rear of the front shaft has the same position nipple and was fine.
Did the other 3 UJ's without issue but there is no way the front of the front will take a grease gun. It will attach but not lock on, flexible hose, rotate shaft etc - no way it was going to work. Gave up in the end.
Bob
Post #90044 19th Sep 2011 7:30pm
jst
Bob, sometimes they put the UJs in the wrong way around which means the nipple points the wrong way - it depends on the type of UJ fitted, some are angled some are just on a flat surface and can't be the wrong way around. i dont know what LR are currently using.
Roel - that greasing advice sounds right to me. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #90047 19th Sep 2011 7:36pm
landy andy
I file flats on two sides of the grease nozzle, this makes it much easier.
Andy
Post #90050 19th Sep 2011 7:51pm
rossy
get yourself a flexible extension for your grease gun. They're only € 5 - 10 at motor factors. Its still not an easy job to do however. Later Defenders do not have nipples on the sliding joints - only on the UJs. Two good pumps are enough. Don't make the mistake I did and keep wacking it in til it comes out of the seals - not good !
Post #90055 19th Sep 2011 8:12pm
bob neville
Thanks all.
James, that sounds like the problem, the grease nipple on the front UJ points to the front, the one on the back of the front UJ also points to the front so I can get the gun attached. Both are angled.
Rossy, got a flexible extension but that does not help.
Andy, will give that a try Thumbs Up
Bob
Post #90060 19th Sep 2011 8:22pm
To do it really properly you should unbolt one end (at least) of the propshaft so that you can fully articulate the joints while greasing. Few folk actually do this though.
Post #90062 19th Sep 2011 8:41pm
bob neville
BW, that is almost what I did out of frustration !
I think James hit the nail on the head, the UJ is fitted the wrong way round so there is no way the gun will connect correctly.
I will drop the front shaft at the weekend and do the job properly.
Bob
Post #90064 19th Sep 2011 8:47pm
mick
England 2010 Defender 130 Puma 2.4 HCPU Rimini Red
Dealer told me there are no nipples on the front propshaft Neutral
Post #90073 19th Sep 2011 10:12pm
