![]() | Home > General & Technical (L663) > Do you keep your Defender clean? |
Digger2000 Member Since: 19 Sep 2020 Location: Newcastle Posts: 590 ![]() ![]() ![]() |
100% agree |
Regan1980 Member Since: 23 Mar 2021 Location: England Posts: 13 ![]() ![]() |
I always keep my cars clean.
I cleaned the new defender for the first time at the weekend. Here in the new forest and I drive on the gravel tracks a lot and it got very dusty (it does look great when filthy) but as others have said you have to clean it. My process: Auto Glym Pola Blast snow foam (I do not pre wash the car, this going straight on the car while its dry and cool) Wait 10 mins and then jet wash with clean water Using a lambswool mitt and two bucket approach. 1st with Auto Glym shampoo conditioner, 2nd just cold tap water (cleans the mitt of any grit before dunking into the shampoo) I go quite slowly with the mitt over the whole car and then the wheels, you cant rush it. Set the jet wash to its rain setting and just rinse the whole car Finally using two micro fibre cloths, 1st to dry down the car then use a second one which is completely dry to remove any final water marks. All in about 40 mins. |
zilch Member Since: 11 Sep 2019 Location: Whitsundays & Sydney Posts: 840 ![]() ![]() |
usually only hand washed, using the one and a half bucket method, it usually starts off as the two bucket method, but after
the first dip of the mitt into the clean water to remove any grit/dirt, i usually forget/give up and just keep using the soapy bucket. The Xpel PPF /ceramic coat forgives many sins ![]() 100 metres from a surf beach, salt spray is a bitch.. so it has to be done yet another pommie bar steward down under MY20 110 P400 SE Defender MY10 3.0 RR Sport |
