![]() | Home > Wheels & Tyres > Offset |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3642 ![]() ![]() ![]() |
If the rim widths (the J number) that you are comparing is the same, then yes.
Edit.. somehow I was thinking about alloys.. but I see that you refer to 'standard steel'. I believe the offset for those is less than 33mm. So the answer might be No. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
v8bob Member Since: 14 Mar 2018 Location: Midlands Posts: 344 ![]() ![]() ![]() |
This explains it better than words....
![]() Click image to enlarge It is stand alone, not compared to any other wheels. |
Leamreject Member Since: 19 Dec 2020 Location: Middle Earth - Leamington Spa Posts: 970 ![]() ![]() ![]() |
That is a great visual explanation, one to keep and share in the future
![]() If I’m not on a bike it’s because only a 4x4 will do… 2011 2.4 Puma 90 HT |
Dixy Member Since: 30 Nov 2020 Location: Somerset Posts: 52 ![]() ![]() ![]() |
Is the offset and stud position the same as 405 Range Rover.
The offset is a feature of the wheel rather than the vehicle.
The stud position (pitch circle diameter or PCD) on a Defender is not the same as an L405 Range Rover so wheels are not interchangeable. It might be the same as the new Defender though, if that's what you mean? Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
