Home > Puma (Tdci) > Fuel cooler 2016 2.2 Puma
Page 2 of 2 <12
natyeo
United Kingdom 2014 Defender 90 Puma 2.2 HT Santorini Black
2012 90 CSW 2.2 had one , current 2014 hard top doesn't 2014 2.2 90 hard top , Warm M8000 , Scorpain winch bumper, Ashcroft rear atb
2012 2.2 tdci 110 Utility
1993 110 CSW Warn M8000 , Scorpain winch bumper , 2" lift , Roamerdive overdrive, on going
1971 Hybird 200tdi, 2 x truetracs,Extrem winch bumper, M8000, GKN overdrive & Coils 2" lift, Glynn Lewis cranked rear trail arms
1971 Series 3 88, Perkins 4203,M8000,SATs,O/D,
Post #898072 13th Apr 2021 8:55pm
RustyM
England 2016 Defender 110 Puma 2.2 XS CSW Corris Grey
Hi All,
So what we can see is there seems to be a more random installation of the fuel cooler Shocked
So what I would like to know is if it is a cooler or not Question
As cooler fuel in hot climates makes a lot of difference Exclamation
Thanks for all of your help so far Bow down Thumbs Up 90 & Wolf
110 XS
Previously owned SI SII SIIa SIII & Light weight (air portable)
Post #898382 15th Apr 2021 9:57am
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
The workshop manual says
"The return connecting line returns excess fuel from the HP fuel pump and the fuel injectors to the filter via the fuel cooler.
To prevent filter waxing at low temperatures, a thermostatic diverter in the filter routes a proportion of the warm return fuel into the filter and back into the supply line to the engine."
So the fuel is cooled down but still warm enough to warm up the filter in winter Question
And what has changed around 2014 that LR thought they could remove the cooler?
Post #898436 15th Apr 2021 2:29pm
Angus_Beef
Norway 2015 Defender 110 Puma 2.2 SW Corris Grey
Im wondering if it's not a complication that is simply not needed. Ive had my 2015 2.2 without this part everywhere from the heat of Sardinia to the cold of the north of Norway and had no problems whatsoever.. Roaming around 🇳🇴🇨🇭
Post #898439 15th Apr 2021 2:51pm
Marks Landy
United Kingdom 1985 Defender 90 200 Tdi SW Java Black
Once the return fuel has had chance to warm the fuel filter will prevent waxing.
Starting from -10C with alleged winter fuel my filter didn’t get chance to warm up and wouldn’t start. Sad
Post #898475 15th Apr 2021 5:53pm
RustyM
Hi All,
So the function of this part that some have and others don't seems to be for hot & cold climates...
Question So is it worth fitting it or not? There is the lubrication factor of hot diesel to consider also Exclamation Question
Anyone in SA have a fuel cooler or not?
Well I am more than curious now...
Thanks for everyone for your input.
M 90 & Wolf
110 XS
Post #898635 16th Apr 2021 2:49pm
macfrank wrote:
... And what has changed around 2014 that LR thought they could remove the cooler?
Perhaps the fuel filter was also deleted! Rolling with laughter
I suspect that they found that the electric in-tank pump on the 2.2 made the filter warming system unnecessary and were trying to save a few pennies.
Post #898645 16th Apr 2021 5:02pm
macfrank
Laughing
It's still there Very Happy
As I understand the manual the filter is warmed by the return fuel after it went through the now-missing cooler?
Technical rationale aside this may probably be the actual reason Rolling Eyes
Post #898705 16th Apr 2021 9:32pm
You're right of course! That's why they say that the brain should be engaged first, and why they say it's better to be silent and thought a fool than to speak up and remove any doubt! |I didn't think that one through, did I?
Perhaps they found that with the tank pump more heat is needed in the filter!
More likely they decided that it didn't make a difference and thought they'd save a few pennies. It wouldn't surprise me if the bypass pipe thingy costs more than the cooler though, knowing the logic of Landrover pricing.
Post #898710 16th Apr 2021 9:48pm
macfrank
Very Happy
Post #898727 17th Apr 2021 8:33am
RustyM
Hi All,
So retro fit or not Question Whistle 90 & Wolf
110 XS
Post #899111 20th Apr 2021 8:51am
RustyM wrote:
So retro fit or not?
Follow the simple questionnaire below:
Q1. Do you have a problem? If yes, go to question two. If no, don't fit fuel cooler.
Q2. Is your problem likely to be solved by fitting a fuel cooler? If yes, fit fuel cooler. If no, don't fit fuel cooler.
Simple! Thumbs Up
Post #899160 20th Apr 2021 2:03pm
RustyM
Hi,
Problem no, I am more concerned of the possibilities of lack of lubrication from high temp fuel Question
As far as I am aware the hotter diesel fuels get the lower the lubrication properties if the fuel Exclamation Whistle
So yes I get the "if it is not broken don't fix it" but I want to avoid drastically shortening the life of the parts that are lubricated by the fuel Rolling Eyes
Thoughts? Question 90 & Wolf
110 XS
Post #900187 27th Apr 2021 10:54am
Angus_Beef
I was curious about this myself so I did a little test. My 2015 2.2 does not have the fuel cooler. Using the BAS RRC tool, I measured the fuel temperature while driving on the highway. Running the 170 tune and cruising at 75-80 mph the fuel temp registered 26-33 degrees C when the air temperature was 22 degrees and coolant temp varied between 88 and 92 C.
When stopped just off the high way with a hot engine turned off, the temp would climb to close to 40 degrees and then drop. This tells me the temp sensor must be under the hood somewhere to get the heat-soak while immediately stopped.
Since the fuel "cooler" is actually just a heat exchanger between return fuel and engine coolant, it seems that this device would be more of a fuel warmer than cooler. Maybe someone who has the fuel cooler can try the same test? Roaming around 🇳🇴🇨🇭
Post #900195 27th Apr 2021 11:44am
Page 2 of 2 <12
