Home > Wheels & Tyres > How to clean alloys?
johnnyd
Washed winter off the Defender yesterday, I used a brush on the alloys and the front 2 came up very clean, but both the rears would not rid themselves if the black/brown crap on them, tried a toothbrush today with washing powder and its still quite solid, why are they different to the front, and what will loosen it?
Front
rear
 2008 TDCi 2.4 XS CSW
Post #898158 14th Apr 2021 11:24am
discomog
I use Valet Pro's Bilberry wheel cleaner. Spray on, dwell for 5 minutes then power wash off. You can use it undiluted for stubborn stains and it's pH neutral. Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #898159 14th Apr 2021 11:32am
johnnyd
Why such a difference between front and back though?
JD 2008 TDCi 2.4 XS CSW
Post #898160 14th Apr 2021 11:46am
BADCADI
Switzerland 2010 Defender 110 Puma 2.4 CSW Alaska White
Same brake pads back and front? Had this problem once on another car when I switched one axle to a different brake pad manufacturer - that dust was painful to get rid off.
BADCADI
Post #898172 14th Apr 2021 1:05pm
Angus_Beef
Norway 2015 Defender 110 Puma 2.2 SW Corris Grey
I have found Sonax to work very well on brake dust
 Roaming around 🇳🇴🇨🇭
Post #898181 14th Apr 2021 1:37pm
bear100
Gtechniq have Fallout remover, turns iron particles purple and kind of liquifies them, makes them easy to clean!
Then coat them with Gtechniq Wheel armour and your set......just a spray with fallout and a rinse then on, they have a really good range of top quality gear
Thumbs Up Thumbs Up 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #898237 14th Apr 2021 6:06pm
Griff90bowler
Wales
Red 7 fallout remover better than any alloy wheel cleaner
Post #898250 14th Apr 2021 7:08pm
markb110
The great man, he says use oven cleaner.....
Post #898257 14th Apr 2021 7:52pm
Ianh
I use bilt hamber auto-wheel. Really good stuff and award winning https://www.bilthamber.com/auto-wheel
Post #898264 14th Apr 2021 8:02pm
Bluest
I use Bilt Hamber too, great stuff. 2007 110 TDCi Station Wagon XS
Post #898266 14th Apr 2021 8:04pm
Marks Landy
United Kingdom 1985 Defender 90 200 Tdi SW Java Black
Another vote for Auto Wheels by Bilt Hamber.
I can’t fault any Bilt Hamber products, cracking value.
Post #898267 14th Apr 2021 8:06pm
Ianh
I buy most of my cleaning products from them. Their auto wash only requires one teaspon full for a whole bucket. Their snow foam is amazing, Clay bars, surface cleaner, polish, double speed carnauba wax etc all win awards.
Ps. I have no connection with them,just their products do what they say and are reasonably priced.
Post #898271 14th Apr 2021 8:12pm
trailbear
Yep, Bilt Hamber for me too, brilliant stuff
Post #898320 14th Apr 2021 10:35pm
I find the best way of helping prevent it is to wax your wheels, quite heavily. That will help a lot.
The front brakes do most of the braking and the fact that they turn means the brake dust has the chance to flow between the alloys.
Around the wheel nuts is the biggest pain to get off due to the small gaps. _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #898326 14th Apr 2021 11:07pm
ericvv
Twice a year when changing winter for summer rims and vice versa, my tire center will put my wheel/tire combos in their wheels washing machine. 5 minutes per wheel, and the plastic pellets in the water jets won’t leave a trace of dirt and brake pad dust a chance, even the inside of the wheels are like brand new afterward. All this without any damage to the rims finish. At the equivalent of £2.50/wheel this quickly has become standard procedure for 10 years now.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #898335 15th Apr 2021 5:56am
