![]() | Home > Td5 > Coolant Top Hose replacement type (Different?) |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2242 ![]() ![]() ![]() |
Quite a few aftermarket hoses are made up in that way as it is cheaper for them to make up a lot of complex hoses without special tooling. I am using some of that type of adaptors to make the bottom hose on my V8 and the plastic bits are fine.
Be aware that you might want to replace the water outlet on the cylinder head though as I have had trouble with mine leaking for years. I fitted a new genuine outlet, genuine hose and replaced the spring clip with a proper JCS hi-grip before it stopped weeping. However the new outlet only lasted 3years before it corroded again and started weeping (I use the correct anti-freeze mix too). Cheers, Steve 02' 110 TD5 Double Cab Rebuild Thread |
PCH114600 Hose-radiator top coolant |
LANDROVER Member Since: 13 Feb 2016 Location: EAST OF ENGLAND Posts: 232 ![]() ![]() |
Thank you! I will fit it at the weekend and the new thermostat. I have replaced the water outlet and it still leaks so thought I would replace the hose incase it's mishaped due to the old outlet. I will replace all the spring clips as I note it's very wet with coolant. I think I may invest in a low coolant alarm also just to be extra safe. Thank you. ![]() |
Smyles_ Member Since: 26 Aug 2018 Location: Copenhagen Posts: 520 ![]() ![]() |
I also believe they are made up this way to prevent the re-occurring issue of them failing at the joints, like yours has.
Mine decided to split along the seam where 2 pipes meet just after new years and right at the top of Scotland ![]() Also, word of warning; the main section of hose that replaced mine was a little too long causing it to kink between the blead valve and rad, despite being flush right up the connectors. Stuart ![]() Cummins 130 Build Thread 58 130 Double Cab HCPU - Cairns Blue 04 110 Double Cab - Black (gone) 07 Audi RS4 Avant - Silver |
