![]() | Home > Puma (Tdci) > Engine Power Cutting |
Race.it Member Since: 27 Aug 2019 Location: Algeciras Posts: 839 ![]() ![]() ![]() |
I know BMW’s from the e46 model onwards do that (stops heal and toe 😢) but if you disconnect the MAF then no problem on accelerator and brake. Maybe the defender has the same, not tried heal and toeing in the defender yet 😂😂 Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17874 ![]() ![]() ![]() |
Yes, entirely normal on the Puma, and in fact normal on most drive-by-wire vehicles. it's also very annoying if you need to dry the brakes, or keep them dry when fording by keeping light pressure on the pedal. (It is also a subject I have vented about several times before on this forum!) |
skidrov Member Since: 06 Oct 2013 Location: Melbourne Posts: 56 ![]() ![]() ![]() |
You can heel/toe in a Puma - standard daily practice. It's a driveline preservation technique as much as a performance technique.
So good to know it’s possible, I know it’s good for the power train etc just on more modern cars I normally hit an issue when you press the brake pedal the accelerator basically is useless. Searching for my first Defender...and started just as Covid hit, so talk about timing.
nickhodgson Member Since: 08 Dec 2009 Location: Zambia Posts: 174 ![]() ![]() |
Funny I thought the car was broken........this is the third 2.4 Puma that I have had and had not noticed any issue on the previous two Pumas.
![]() 2011 Puma Defender 130 D/C 2000 300tdi Defender 110 P/UP 2015 Discovery 4 SDV6 HSE |
Perhaps the last two were broken!
