![]() | Home > Puma (Tdci) > Engine Power Cutting |
| Race.it Member Since: 27 Aug 2019 Location: Algeciras Posts: 845
I know BMW’s from the e46 model onwards do that (stops heal and toe 😢) but if you disconnect the MAF then no problem on accelerator and brake. Maybe the defender has the same, not tried heal and toeing in the defender yet 😂😂 Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18047
Yes, entirely normal on the Puma, and in fact normal on most drive-by-wire vehicles. it's also very annoying if you need to dry the brakes, or keep them dry when fording by keeping light pressure on the pedal. (It is also a subject I have vented about several times before on this forum!) |
| skidrov Member Since: 06 Oct 2013 Location: Melbourne Posts: 56
You can heel/toe in a Puma - standard daily practice. It's a driveline preservation technique as much as a performance technique.
So good to know it’s possible, I know it’s good for the power train etc just on more modern cars I normally hit an issue when you press the brake pedal the accelerator basically is useless. Searching for my first Defender...and started just as Covid hit, so talk about timing.
| nickhodgson Member Since: 08 Dec 2009 Location: Zambia Posts: 174
Funny I thought the car was broken........this is the third 2.4 Puma that I have had and had not noticed any issue on the previous two Pumas.
2011 Puma Defender 130 D/C 2000 300tdi Defender 110 P/UP 2015 Discovery 4 SDV6 HSE |
Perhaps the last two were broken!
| All times are GMT |
