Home > Off Topic > Transverse engined 4x4 with transfer box. Does it exist?
Mountain_man
Wales
Just thinking outside the box. Can anyone identify a 4x4 vehicle that has been built with a transverse (front) engine that also has a HI/LO transfer box?
Post #894423 28th Mar 2021 8:29am
excossack
Old Fiat Panda 4x4 ? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #894456 28th Mar 2021 11:01am
Mountain_man
Wales
From Wiki..
The Panda 4x4 was launched in June 1983, powered by a 965 cc engine with 48 bhp (36 kW) derived from the Autobianchi A112 or Fiat 100 series engine. Known simply as the Panda 4x4, this model was the first small, transverse-engined production car to have a 4WD system.[citation needed] The system itself was manually selectable, with an ultra-low first gear. Under normal (on-road) conditions starting was from second, with the fifth gear having the same ratio as fourth in the normal Panda. Austrian
So no cigar Wink
Post #894470 28th Mar 2021 12:28pm
Mountain_man
Wales
EDIT: Post removed
Post #894471 28th Mar 2021 12:31pm
excossack
Ahh. I vaguely remembered a lever between the front seats (other than gearstick/hand brake)
Subaru Justy 4x4 ? 1999 Defender TD5 110
Regards
John M0VAZ
Post #894472 28th Mar 2021 12:55pm
Philip
Can’t think of anything beyond the some of the old Japanese systems (like the Toyota Tercel) which had a lower main-gearbox first gear only accessible in 4WD.
Post #894473 28th Mar 2021 1:07pm
Mountain_man
Wales
Haha, that was my removed post. I thought of the Justy (I still have a scrap one under the hedge), but they only had a 4WD shift button on the top of the stick. No transfer box. My old Imprezza 1.8 and the GLF I had before that had a HI/LO transfer box, but they were fitted in line behind the flat 4 engine. They were unusual though in that the Diff and driveshafts for the front axle came out of the front of the gearbox so there was no front propshaft as such. I don't think it had a seperate transfer box either, rather all the gubbins for the low ratios were inside the main gearbox. Clever cars they were to be fair.
Post #894474 28th Mar 2021 1:08pm
90 Dreamer
Yes Subaru has one main casing that contains the ggearset, front diff and centre diff units........but basically RWD style arrangement behind the engine
Post #894487 28th Mar 2021 2:13pm
My mum used to have a Tercel.
Engine dropped a conrod IIRC. shame was a good car.
Post #894492 28th Mar 2021 2:34pm
lohr500
2014 Jeep Cherokee Trailhawk
Post #894520 28th Mar 2021 5:36pm
Philip
Good call - think they’re more gear reduction units front and rear rather than a transfer box as such, but I doubt there’s anything much else.
Post #894522 28th Mar 2021 5:59pm
lohr500
Think it is a proper two speed transfer case in Active Drive II configuration :
https://www.topspeed.com/cars/car-news/a-d...79348.html
Post #894525 28th Mar 2021 6:08pm
Philip
You'll have to use a VPN or similar to read it:
https://www.fourwheeler.com/vehicle-review...cherokee-/
"Traditionally, we would give you the rundown on the transfer case next, but one doesn’t exist in this platform. In its place is a PTU (power transfer unit) that splits power to the rear differential. Instead of having one set of low range planetary gears in the transfer case, the 2.92:1 planetary gears are placed with each differential assembly. This unique system provides gear reduction, but without the parasitic loss and weight of a transfer case. This system was not only innovative, but necessary since the unibody Cherokee is based on a front-wheel-drive platform-one that is shared with Fiat and the Dodge Dart"
Post #894552 28th Mar 2021 7:44pm
lohr500
Thumbs Up
Post #894554 28th Mar 2021 7:50pm
