Home > For Sale & Wanted > worklight wanted
22900013A
worklight wanted
I am after a worklamp for the back of my 110 Tdci, I would like the while kit including the dash switch etc.
Thanks. 2011 110 USW
1973 Series III 1-Ton
1969 IIA 1-Ton
1966 IIA 88"
Post #89284 15th Sep 2011 7:10pm
BigMike
available on ebay for about a tenner mate. or have a word with boab. cheap.
Post #89295 15th Sep 2011 8:15pm
22900013A
I have looked on ebay and genuine ones look to be about £55 or so, but I am concerned they don't have the proper dash switch etc...which kit should I be getting? 2011 110 USW
1969 IIA 1-Ton
1966 IIA 88"
Post #89334 15th Sep 2011 10:07pm
BigMike
Do you need or want a "genuine" one? It's just a light after all.
I use a spot with a clamp to an aux power socket in the back so it can be removed. If I need a light behind and can't be bothered I leave the engine on, put the transfer box in neutral and put the main lever in reverse. Hey presto - worklight
Post #89337 15th Sep 2011 10:11pm
Landie Boy
United Kingdom 2010 Defender 110 Puma 2.4 USW Stornoway Grey
Hi, I have the genuine one fitted and it does not come with a dash switch. They have 2 switches, one on the light and one inside which is placed in the plastic interior piece.
Jack
Post #89341 15th Sep 2011 10:40pm
Landie Boy
Thinking about it, from where you usually take the power feed a switch up front would be a really hard to achieve unless you were willing to run a separate fused and relayed wire to the back.
Jack
Post #89349 15th Sep 2011 11:26pm
22900013A
The old SSE ones I used to drive had worklights with a dash switch. If it is outside mounted I can live with that. I would rather have a genuine one than an aftermarket jobby. 2011 110 USW
1969 IIA 1-Ton
1966 IIA 88"
Post #89369 16th Sep 2011 7:38am
Whilst I understand your desire for a genuine one - I like some of the OEM goodies myself - I think where it comes to this sort of thing you're selling yourself short. There are so many excellent options - some of the new LED lights, for example - that the only benefit of buying genuine in this case is that it will come in a box with Land Rover printed on it. Then it will just be a re-badged version of something that you can buy cheaper elsewhere anyway, such as Hella, Wipac, or similar. Darren
Post #89386 16th Sep 2011 10:24am
Id get a Mobile Centre one Thumbs Up
Post #89388 16th Sep 2011 10:31am
DAZ110
Hello 22900013A
If you are looking for a RTC8921AA Landrover worklight I have one available in as new condition (never been fitted) with mounting bracket, bolts, switch and wire but no instructions. Yours for £30 + postage @ £6.43
PM me if your interested
Thanks
Daz110
Post #89437 16th Sep 2011 4:49pm
22900013A
DAZ110 wrote:
Hello 22900013A
Thanks
Daz110
You have a PM.
Dan 2011 110 USW
1969 IIA 1-Ton
1966 IIA 88"
Post #90207 20th Sep 2011 6:57pm
