Home > Off Topic > Drill bit
L110CDL
Drill bit
It's time i had a drill bit sharpener, so my go to place is here Very Happy
Which one would you recommend and why ?
many thanks
Thumbs Up Clayton.
Keeper.
Post #892211 17th Mar 2021 10:54pm
Bluest
Bench grinder and learn to do it manually. I was taught by my Dad, a toolmaker, but theres loads of vids on the ‘net. The advantage of this is you can make specials. Need a spot weld drill? Grind one from a twist drill. Need to drill into hardened steel? Regrind a masonry drill. It’s most satisfying. 2007 110 TDCi Station Wagon XS
Post #892219 17th Mar 2021 11:27pm
Dinnu
Bench grinder. It takes some practice, but once you hone your skill, you will get to grind any shape you want. Not all drill bits are the same. Plus you can grind chisels, center punches, you name it.
I would suggest the best you can afford. And then true your wheels as well. A grinder that vibrates would not give you good results.
My 2c. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #892220 17th Mar 2021 11:29pm
https://uk.rs-online.com/web/p/bench-grinders/3890777/
Cheaper version are available. Used with a suitable bench grinder this type allows accurate sharpening of a very wide range of sizes.
Post #892221 17th Mar 2021 11:30pm
Or if you have the money go Tormek, T-8 or T-4 with appropriate jig:
You'd need to have a lot of dull bits to get your moneys worth.
Post #892240 18th Mar 2021 7:57am
Leamreject
Italy 2011 Defender 90 Puma 2.4 HT Fuji White
I use a bench grinder, I can control the shape pressure and heat generated to get the best result for the drill bit. Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do…
2011 2.4 Puma 90 HT
Post #892245 18th Mar 2021 8:28am
donmacn
ANother vote for a bench grinder and a few instructional videos.
If I can manage this, then a hands on/practical guy like yourself would have no problem. (I was going to say 'master this' - but that would have been wrong!)
With my grinder, one of the 'rests' has a groove in it to help you get the right angle for drill bits. I'm sure I'm not brilliant at this, but if I feel I'm getting nowhere with the drill, whip it out, a few secs on the grinder, and the difference when you come back to the job is really noticeable.
I've also learnt more over the years about specific speeds for specific metals, and the benefits of lubrication and stopping if things get too hot..... Whistle Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #892268 18th Mar 2021 10:06am
miker
I really need to sort my bench grinder out with a new stone, but to get used to it, even an average sharpen can be a huge benefit. In a pinch, I've managed to get a decent edge back onto drills with an angle grinder...
Post #892273 18th Mar 2021 10:11am
Hardcore tool porn of the highest order! Oh, the palpitations! I think I need to lie down for a bit. Rolling with laughter
Post #892287 18th Mar 2021 10:44am
Hey man maths at it's best when you can justify a 4 figure spend to be able to sharpen a jobbing bit worth pennies. Whistle
Post #892326 18th Mar 2021 1:57pm
Rashers
Bit off topic, but still drill orientated, what drills do you all buy.
When I used to work on site, 25 years ago, we got Presto HSS drills from the local engineering merchants in Norwich. They were mostly 6mm (for what we did) and they would last for months (we used to drill holes in metal electrical containment). The drills I have purchased recently have been rubbish. In fact, I have resorted to going back and using some of those drills from my past life as the new ones are no good.
Might be worth trying to sharpen some of these old drill bits up. I do like that drill sharpening machine Thumbs Up
Post #892365 18th Mar 2021 4:42pm
rallysteve
I generally use the cobalt bits from Toolstation as cheap general purpose metal bits. I have found their performance and durability excellent as long as you don't get carried away with the speed/pressure.
https://www.toolstation.com/power-tool-acc...l-bits/c82
I am slowly replacing my Dewalt extreme bits with them as required as the Dewalt ones are far too aggressive for thin sheet use in a hand drill.
Despite cobalt bits meant to be more durable than HSS, I find that using a bit of cutting lubricant helps no end.
Post #892381 18th Mar 2021 5:17pm
jaygti
United Kingdom 2002 Defender 90 Td5 HT Epsom Green
We use hertel drills almost exclusively at work now on small stuff.
6 mm or under get chucked in the bin when they’re blunt. 6 to 10 mm might get ground up.
Generally we just just use carbide drills that are close and then bore to size.
This is an 11mm carbide drill. It’s so fast it’s almost like a hole punch. 2002 td5 90 county hardtop
Post #892387 18th Mar 2021 5:36pm
Dinnu
Carbide is the hardest and will maintain the sharpness for longest, but very difficult not to chip it or break it on a hand drill. So best is to use carbide on a good drill press or milling machine.
Cobalt is also very good, and can even drill hard materials like 12.9 bolts even on hand drills.
High speed steel (HSS) should be adequate for normal use, but some cheap HSS are only good for drilling cheese, or plastics.
And since I mention plastics, I go back to the original topic.. drill bits sharpened for steel/metal is not ideal to use on plastic as they will bite too much/fast in plastic. Drill bits for plastic generally have a flat cutting edge, that scrape the material rather than digging into it. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #892488 18th Mar 2021 10:46pm
L110CDL
Thank you all for your reply's Thumbs Up
I noticed in the you tubes that the angle grinders were larger than i have, the 2 i have are smaller, so one works of battery and the other is electric, will these be ok to use ?
Also do you have to have special disc's or as i saw in the tube a pad with a stick on paper disc ? this is all new to me, thank you again Very Happy Clayton.
Keeper.
Post #892718 19th Mar 2021 10:55pm
