Home > Off Topic > Drill bit
Page 2 of 2 <12
Dinnu
A 125mm angle grinder has more than enough power to grind a drill.
The problem is that standard grinding discs for angle grinders are too coarse for the application, and if you have just fitted it, they normally vibrate a bit because they are made so cheaply.
Yes, you have the option to fit a sandpaper backing disc. Then you have a wide range of sandpaper grades to fit. Unsure which paper grit size would give you the best result, but my guess 180-360 would be the range to test. You would be able to get a good sharp drill this method, but you would probably also be going through a lot of sandpaper discs. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #892760 20th Mar 2021 7:24am
L110CDL
Thank you Dinnu Thumbs Up
I think i need to do some more homework on this, thank you all for your reply's Thumbs Up Clayton.
Keeper.
Post #893320 22nd Mar 2021 11:37pm
Page 2 of 2 <12
