![]() | Home > Puma (Tdci) > Engine, Gearbox & Transfer Box Oil Change |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2516 ![]() ![]() |
Just looking at my manual for my 2013 2.2 and it says 2.4 litres refill as pictured above, no mention of dry fill quantities. I wonder why they changed that from the 2.2 litres refill and 2.4 litres dry fill for the earlier puma 2.4’s ? mistake in the user manual or should the 2.2 pumas be refilled with an extra 200ml of transmission oil. Views appreciated. Ps . Will be doing all the fluids in a weeks time so will measure what comes out. |
v8bob Member Since: 14 Mar 2018 Location: Midlands Posts: 344 ![]() ![]() ![]() |
Both the Defenders I have had, both main dealer serviced. On the first service the dealer charged for some transmission oil and topped up the transmission
To answer my own question. On draining my gearbox I measured 2.4 litres exactly. So it does look like the owners manual is correct for the 2.2 puma. I.e 2.4litres refill. I therefore filled with 2.4 litres of fresh castrol syntrans multi vehicle 75w -90. I did the transfer box and the diffs at the same time. Re the diff fill and drain plugs, I can’t find the torque settings for these. So I torqued at 30Nm. Is this correct ? I read somewhere on here it should be 60Nm but that seemed to much as at 30Nm it seemed tight enough. It would be good to know the official figure. |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3614 ![]() ![]() ![]() |
Thank you for the info. I could not be sure on the amount of drained oil as it was leaking and I was guess topping. Incidentally 2.4liters had came out as well, so I was spot on.
As for torque figures, this might help. https://www.defender2.net/forum/post37498.html 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Thanks dinnu , I will keep an eye out for leaks on the diffs, I replaced the diff drain plugs using magnetic ones from megasquirt-v8 and used some loctite 248 blue on the threads and expect at 30Nm it will be ok. If not I will tweak a little more towards 55 -60 Nm or drain and use some hylomar blue on the plugs, just did not have to hand to use today.
On the gearbox I used magnetic drain and fill plugs from foundry4x4. Don’t think I needed magnetic fill plug as oil does not reach there but prefer the hex bolt head over the 8mm Alan key head. Noting i think the MT 82 gearbox has a magnet in the bottom already, but fitted magnetic plug as a belts and braces solution. The transfer box already has a magnetic drain plug. Ps I used a 1.2m length of 12mm clear plastic tube with a funnel connected from the engine bay, worked perfect to fill the gearbox and very easy to do, just let gravity do all the work. |
TamarBlue11 Member Since: 25 Sep 2020 Location: England Posts: 243 ![]() ![]() ![]() |
Just to double check, would I be OK to use this in the diffs? The book says 85w-90. Do I need to put anything around the threads when I put the plugs back in? Cheers
![]() Click image to enlarge https://www.ebay.co.uk/itm/284281644869?ha...SwypJgkCLD |
Yes, that will be absolutely fine.
You shouldn't need to put anything around the threads if everything is clean and in good condition. Having said that, if you're doing this for the first time then I'd recommend investing in some new magnetic drain plugs. I seem to remember that the ones that I fitted a few years ago came with a coating on the threads. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Great thanks, any recommendations for best place to get magnetic drain plugs?
Mine came from eBay. Search for 'Defender magnetic diff drain plug'. Darren
Thanks, will look on ebay.
Decided to go for this instead as was cheaper, which I assume is just as good for the diffs, 4x of them for just under £30 from Euro!
That'll be fine, too. Darren
Thanks Darren, much appreciated for the advice.
110NTK Member Since: 24 May 2021 Location: essex Posts: 20 ![]() ![]() ![]() |
just an FYI - anyone with a 2.2 from 2012-2014, don't trust the auto pick from most websites....ordered the genuine land rover service kit, inc FoMoCo screw type metal filter.
dumped the oil, and in my own stupidity (1st defender, 1st time doing a DIY oil change...EVER) clocked the oil filter had a hex bolt on it...hoped/wished it was just a cover for the metal filter, removed to find a nice oily paper filter.... 8am to Eurocar parts to pick up the correct one tomorrow am.... hoping no one try to steal it tonight when its bone dry with no oil! now checking the vins can see my bad, im DA431..the metal screw ons are DA444 will also swap out the file filter tomorrow - hopefully theres only one of those! |
