![]() | Home > Technical > Front diff oil change |
| I Like Old Skool Member Since: 23 Feb 2015 Location: Manchester Posts: 882
Ouch. At least it isn't too difficult to swap out.
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6052
Get yourself a new/stronger front diff. Rover ones are weak, especially in the front.
| Sicastle71 Member Since: 21 Aug 2019 Location: West Lancs Posts: 128
Would that be a p38 diff is it just a straight swap off the diff nose
I would fit a LSD. They are better for traction and much much stronger. Yours will be a rover diff, not a P38.
https://www.ashcroft-transmissions.co.uk/l...t-atb.html |
| jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8480
P38 diffs only went in the rear. the housing wont fit the front. i suggest pull whole wheel station form axle to change its alot easier, mind the brake lines if in doubt calipers off. only 7 bolts each side then. Cheers
At keast all the bolts will come out just rebuilt the swivel seals and hubs with all new bearings and bolts thank for the help 😀
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18033
I'm sure I remember someone else quite recently reporting this happening, in one of the "diff failure" threads.
