Home > Technical > Front diff oil change
Sicastle71
England 1999 Defender 90 Td5 CSW Alaska White
Well just changed the front diff oil and after removing the drain plug seems one of the crown wheel bolt has sheared
Never have I seen this before
Post #890801 11th Mar 2021 7:42pm
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
Ouch. At least it isn't too difficult to swap out.
Post #890816 11th Mar 2021 8:54pm
landy andy
Get yourself a new/stronger front diff. Rover ones are weak, especially in the front.
Post #890818 11th Mar 2021 9:10pm
Sicastle71
Would that be a p38 diff is it just a straight swap off the diff nose
Post #890829 11th Mar 2021 9:50pm
landy andy
I would fit a LSD. They are better for traction and much much stronger. Yours will be a rover diff, not a P38.
https://www.ashcroft-transmissions.co.uk/l...t-atb.html
Post #890836 11th Mar 2021 10:05pm
jst
P38 diffs only went in the rear. the housing wont fit the front. i suggest pull whole wheel station form axle to change its alot easier, mind the brake lines if in doubt calipers off. only 7 bolts each side then. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #890846 11th Mar 2021 10:35pm
Sicastle71
At keast all the bolts will come out just rebuilt the swivel seals and hubs with all new bearings and bolts thank for the help 😀
Post #890858 11th Mar 2021 11:36pm
I'm sure I remember someone else quite recently reporting this happening, in one of the "diff failure" threads.
Post #890899 12th Mar 2021 10:16am
