Home > Maintenance & Modifications > Puller for intermediate output shaft
PCM
Does anyone know of a decent 2 legged puller to get the cup off the output shaft on a puma.
They seem to be in the region of £50-250
Don’t mind paying the money for a big Censored but worried it won’t fit in the housing.
What do people use?
I have access to a lift for a day so want to be prepared.
PCM
Post #890347 10th Mar 2021 6:55am
Co1
Can you weld a couple of studs to it and use a slide hammer? This is how mine was done.
Post #890361 10th Mar 2021 8:57am
PCM
Possibly. However all the you tube vids just use a 2 legged puller but winge on about access. Confused
Post #890426 10th Mar 2021 12:40pm
If you remove the extension housing from the back of the gearbox, access is very easy. I really cannot understand why anyone would attempt the job without removing the housing!
Post #890436 10th Mar 2021 1:26pm
PCM
Thanks Black wolf. That makes sense to me.
Just assumed looking at some guides/vids that you can just persuade the thing off using a puller around the old cup either onto the housing or screwed onto the loosened nut.
I'm looking at doing it myself (with assistance) so any tricks appreciated. Naively quite looking forward to it really.
Post #890461 10th Mar 2021 3:19pm
I think that sometimes they do just slide off, but they shouldn't and it probably isn't good news if they do. I have changed about 3, and always removed the housing and then used either an SP three-leg puller or an SP bearing separator, I honestly can't remember which (I think the standard 3-leg fits fine).
Getting the new one on can be more tricky, the manual says you should heat the "cup" to 100 deg Celsius before fitting, but some are still tight at this. Be very careful if you try to use the centre bolt to pull it on, as the washer can shatter, and you really don't want to risk damaging the mainshaft threads. You are better off fitting a threaded stud in the hole and using a plate and nut to pull it into place, or use a soft-face hammer.
Post #890550 10th Mar 2021 8:34pm
jst
likewise i just remove the extension housing, makes life simpler. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #890575 10th Mar 2021 9:50pm
Only people who enjoy pain and swearing would attempt the job without removing the housing! Rolling with laughter
Post #890593 10th Mar 2021 10:35pm
