![]() | Home > My Defender > Fuji 110 LS3 build |
| mcma1 Member Since: 16 Oct 2012 Location: Northern Ireland Posts: 2947
Got the gear linkage adjusted to engage the tiptronic. You get a pretty average gear indicator with the shifter kit but rather than not use it i have put in somewhere I can at least see it, can get a nice digital one for the dash if I find it useful.... The tiptronic is excellent, no DCT but good changes. I find using the switch on the selector a bit awkward though as the gear stick is fully to the back and I dont want to add seat extenders so I dug out the old paddle shift kits I had from the last LS. These never really worked well as they used a bluetooth connection to the electronic shifter but I am going to try and make use of these and basically just turn it into a second switch.
Click image to enlarge Click image to enlarge Click image to enlarge Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
| Linds Hanson Member Since: 16 Jan 2021 Location: Cornwall Posts: 529
Always wondered how they worked without a clock spring! How are you planning to connect without BT?
Sorry didn’t really explain. These paddle shifters are from my last LS which had a push button gear selector and then paddles via a Bluetooth module. I now have a simple rocker resistance switch on the top on the gear stick so I plan to just replicate another switch with the paddles. Andy
Think I discovered the cause of the rough idle and occasional cut off, 10bar fuel pressure
LS engines should be around 52 psi. We fitted a new high flow pump into the tank and then a new 52 psi regulator so it would seem the regulator is shot. Have a new one on the way. Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
| JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7930
10 bar (145 psi)!!
Me too, we thought the first gauge was broken so added a bigger one which had the range. Luckily I have only run 100 miles but won’t go any further until it’s sorted. Andy
| Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3798
I might've missed it, but have we heard the sound of this V8 powered "work of art" working hard under load?
Pickles. |
not yet Pickles...need to sort out the fuel pressure! got a nice new pump and regulator so that should be me back on the road.
Click image to enlarge Also decided to go down the simple route for the tiptronic, just moved the top of the gear knob, quick scan with the laser & reverse engineered it into a printed pod instead of a second cup holder, ideal location for me there. Just need to finish and paint it and then fit a new blank to the gear knob. Click image to enlarge Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
This thread is unreal, I've been involved in cars all my life, all sorts of cars, all sorts of engines/conversions etc, but I don't think I can remember such beautiful "more than professional" work, of such a complex & wide ranging nature, being carried out on a vehicle, & more particularly, where all the work has been designed, planned, & actually "done" by one person. Simply amazing.
Pickles. |
| GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10385
Something looks like there’s something giving birth on the centre console
Oh dear god Steve!!! Now I can't unsee that!!!
| Oakseywick Member Since: 20 Dec 2014 Location: Cirencester Posts: 1002
Defender 90 Defender 110 XS Cupra 290 |
| mrfirepro Member Since: 07 Nov 2020 Location: kent Posts: 235
Looking really good.
I need to buy the fuel system parts for my build any time now, any part numbers/advice/pics will be really useful |
Got this finished and working, new blank onto the gear knob also. Click image to enlarge Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
