![]() | Home > Faults & Fixes (L663) > Intelligent AWD only drives in 2WD |
Digger2000 Member Since: 19 Sep 2020 Location: Newcastle Posts: 590 ![]() ![]() ![]() |
Probably that for the brakes good find
Hopefully it can be fixed 🤞🏻 |
![]() Click image to enlarge Just been out for a drive and again no warnings on start of ignition but I drove over the same patch of pot holed road that brought up the warning ⚠️ sign last time and the same warning came up literally seconds after. I then drove home and inspected the vehicle that’s when I noticed something is leaking (see red circle in photo above, blue arrow is front of vehicle) under the car possibly from the the new clutch transfer case that acts like a differential for the new torque on demand AWD system that replaced the central differential on the MY20 vehicles (see below). ![]() Click image to enlarge Im no mechanic so I haven’t got a clue if this is something major or not but the vehicle as it stands does not work in 4WD or AWD because as soon as the car hits a slightly rough terrain it is triggering the warning sensor to cut power to the front wheels. |
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3495 ![]() ![]() ![]() |
Appalled once again. The world would be up in arms if a Toyota LC or Merc G wagon did this.
We just shrug and say “well you did buy a new LR”... 1951 80" S1 2.0 1995 110 300TDI 1995 90 300TDI |
Philip Member Since: 09 Mar 2018 Location: England Posts: 510 ![]() ![]() |
They all go wrong, the new G Class has been recalled for various things - diff issues, brakes, wiring etc.
I must of hit the jackpot because looks like I have all 3 of them faults
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17786 ![]() ![]() ![]() |
Oil leaks are a part of the Defender heritage!
TomekW Member Since: 21 Feb 2015 Location: Warsaw Posts: 197 ![]() ![]() ![]() |
Digger2000, different question, what are the tyres on your car? they look interesting 2021 Defender 90 D250
1998 TUL 1997 TUM FFR 2003 Defender 110SW Td5 1985 ExMOD 110 ST 3.9 V8 1971 Series IIa Lightweight |
Recalls are never a bad thing ~ if only JLR would embrace them. Instead, they fight them, pretend the issues don't exist and if absolutely necessary issue, quite literally at times, sticking plasters ~ double sided tape, felt pads and tie wraps... |
Can you examine that and see if it's water, coolant, oil. What colour is it? Blot it onto some white kitchen towel. There's been a recent TSB for Velars only with AWD: SITUATION: A transmission fluid leak may be seen coming from below the vehicle. There may also be a lack of acceleration and/or a 'juddering' from the vehicle while driving. A transmission warning message may also be displayed on the Instrument Panel Cluster (IPC). Upon further diagnosis, the fluid may be found leaking from the transmission fluid cooler pipes. CAUSE: Excessive vibration transmitted through the transmission fluid cooler pipes while the engine is running, causing the weld joints to fracture. ACTION: Follow the instructions below. |
Could be that supacat. I will check the underneath ASAP. What were the actions?
New pipes and what could be new/revised brackets.
The leak/liquid is clear ![]() Click image to enlarge |
DSL Member Since: 20 Aug 2007 Location: Wandering the wasteland. Posts: 837 ![]() ![]() |
Water from the AC condenser?
