Home > Modifications & Maintenance (L663) > Retro fit / aftermarket tow bars
thumper1978
Hi Folks,
I am in the market for a new defender 110, given the current wait times for a new one I am looking at dealer stock and used defenders.
I have noticed that a surprising number of them don’t have tow bars, and I need one for towing my stock trailer.
Does anyone know if I could retro fit one, and is there any aftermarket tow bars available as yet for the 110?
Cheers 👍
Post #885790 15th Feb 2021 11:58pm
Digger2000
United Kingdom 2006 Defender 90 Other HT Tonga Green
Yes you can get multi height tow bar it’s on the Land Rover configurator. There used to be a removable tow bar but they have removed it from the website, I’m not sure if that is because of supply issues or if there has been problems with it on other peoples vehicles. There is a guy in the Facebook group who has it and pulls a trailer he’s having major problems with it something to do with the air suspension keeping the trailer too levelled and its clattering up and down on the bar like it’s going to pop off! This only happens when the trailer is empty it sorts itself out once a load is on. His dealership are working with him to sort an alternative out and that’s the multi height one, others in the group haven’t had a problem with that type as far as I’m aware.
Post #885793 16th Feb 2021 12:57am
Digger2000
Post #885794 16th Feb 2021 1:00am
Retroanaconda
There are parts shortages with some towbar options it seems, so I presume that is why it’s been taken off the configurator. The multi-height one above is a dealer-fit accessory and so your dealer could do it for you. You could fit the towbar itself DIY easily enough as it’s just nuts and bolts, but the module needs fitting and the main system telling a towbar is fitted so the various functions are available.
Not seen any aftermarket ones available yet but I am sure it won’t be long. Westfalia make the Land Rover ones.
Post #885883 16th Feb 2021 4:00pm
Buz1500
I had a removable tow bar fitted by a dealer last year but it did take a long time for them to source the required parts. They said that there were significant supply issues due to Covid.
I’ve only used it a couple of times to tow my caravan due to Covid restrictions but I’ve had no issues
Post #886054 17th Feb 2021 9:33am
Lighty
I ordered the full kit fro Landrover on Friday.
1st off they said the module is on back order, now they say just the bar is on back order.
Thing is, you don’t get a delivery schedule unless you order it.
Pretty sure I can code it in myself, we have done plenty of other cars, worst case will be a pass through device to Landrover themselves.
Not getting the car until the end of March, so hopefully the bar will turn up soon enough.
Post #886965 21st Feb 2021 6:51pm
Kingfisher24
Retro fit tow bar
A long day but worth it. Kit from Tow Bars Uk. A great kit. Involved but not complicated.
Post #991720 6th May 2023 9:58pm
Moo
Ukraine
Did you fit the module as well? If not, any issues with the cars functions etc? Eiger Grey MY23 D250 SE with bits. Known as Noddy.
Post #991722 6th May 2023 10:05pm
Kingfisher24
Retro fit tow bar.
Wiring kit and module all plugged in perfectly and cameras and reversing sensors all happy. Bit awkward to access the plug with the seven seats but once the Jack tray removed it was easy.
Adds a lot of weight compared to the aluminium crash bar that it replaces!
Post #991725 6th May 2023 10:54pm
