Home > Maintenance & Modifications > Swapping out the panoramic windows
TomHutch
United Kingdom 2011 Defender 90 Puma 2.4 CSW Zermatt Silver
Hey all, first proper post on this forum. So firstly hello! Had my defender 90 county 2011 for around a year now. Done a few bits and bobs changing it to my liking. I bought it with the panoramic windows, but to be honest I’ve never really liked them. I’m looking at changing out the rear panoramic windows just for either the van or the CSW I’m still not 100% which I fancy. I’m just wondering what my best options would be for changing them out. There’s a lot of info out the for converting to the panoramic windows, but not much the other way.
Option 1. Buying new rear panels and just straight swapping them out. (Colour isn’t too much of a problem as a good friend of mine has his own painting unit). With this option would it be worth just swapping out the rear door as well?
Option 2. To make it a van, I was wondering if it was possible just to drill the rivets off the sides that are currently riveted on to the frames. Then maybe just get a new bit of sheet metal fabricated to spec then rivet that back on? Seems like a bit more work, and not sure whether it’s even a viable option.
Option 3. I’m not 100% sure whether it would work. But fit windows into the space that is already cut out in the side panels. I’ve measured this up and they come up at around 43”x17”. Which when I’ve checked online seem to big to fit the CSW windows (36”x14”?). But again not sure what to do with the rear door.
I appreciate any help and sorry if this is a bit of a stupid question / post! I’ve attached some pictures (I think) just to show you what I’m dealing with.
Post #885518 14th Feb 2021 6:03pm
Bev
Scotland 2003 Defender 90 Td5 CSW Oslo Blue
I think your going to need complete new or replacement side panels as
1. It looks like the hole is now enlarged for the panoramic windows so the originals won’t just slot straight in.
2. I understand those windows are bonded in to the panel so will be a nightmare to remove.
I think your option one is easiest and would give the best results. You can buy a brand new replacement rear door for something like £240 from britpart OEM. Glass would be extra but plenty available on the resale market.
Some photos of mine with the windows removed to painting.
 2002 Td5 | 90 County Station Wagon | Oslo Blue
2006 Td5 | 90 County Station Wagon | Tonga Green (Gone )
2002 Td5 | 90 County Station Wagon | Zambezi Silver (Gone)
Post #885530 14th Feb 2021 6:49pm
Defender SVX
United Kingdom 2008 Defender 90 Puma 2.4 SVX Soft Top Santorini Black
As above it’s looking like to do a good job you’re going to have to swap both panels and rear door, even if the openings hadn’t been enlarged by the time you’ve cleaned off the “Censored to a blanket Rolling with laughter “ adhesive it would probably need repainting.
If you remove the parts as a whole they have some value that will offset the replacements. I’d be interested in them and local to assist replacing Whistle Whistle
Edit to add personally I think it looks spot on the way it is Thumbs Up Formerly mao99999
16 Focus RS Nitrous Blue.
11 FFRR TDV8 Vouge SE Black Black.
08 DEFENDER SVX SOFT TOP (SUPERB)
08 DEFENDER 110 DCPU Stornoway grey (Overland Exploration Unit)
05 Fiesta ST 150 Van
04 Jaguar XKR 4.2 Supercharged V8
02 DEFENDER 90 TD5 (next years soft top project)
95 DEFENDER 110 CSW 300 TDi Phoenix black
95 DEFENDER 90 HT Monti Carlo blue COUNTY 300 TDi
67 109" SERIES 2a TUNED 200 TDI
64 DAVID BROWN 990 rat look
55 86" SERIES 1
Post #885533 14th Feb 2021 6:59pm
Oakseywick
United Kingdom 2000 Defender 90 Td5 XS CSW Java Black
Member 2010blackdefender90 on here has done this he had the glass removed by a auto glass guy I think try and find his posts or it might be in his build thread if he has one. Andy
Defender 90
Defender 110 XS
Cupra 290
Post #885538 14th Feb 2021 7:13pm
Sulisuli
https://www.defender2.net/forum/topic63739...amic+glass
There you go. 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #885552 14th Feb 2021 8:07pm
TomHutch
Thanks for the help guys. Looks like if I go for it it’ll be new panels and door then. Like you say seems more
Hassle than it’s worth trying to remove the glass. I’ll keep an eye out on here and the bay for any going up for sale. I’ve got some new wheels coming next week so gonna see how they look with the defender before
changing anything out.
Change my mind like the wind so I’ll probably end up liking it next week and keep it as is. But very useful info regardless, so thanks a lot fellas I really appreciate it. And thanks for the offer defender SVX, I’ll keep you posted Thumbs Up
Post #885574 14th Feb 2021 10:46pm
JOW240725
Welcome to D2N Thumbs Up Personally, I quite like the panoramic glass, I'd be more concerned with the Khan wingmajigs Shocked Laughing
If you could find someone who wants the panoramic glass you could do a straight swap? James
Instagram @suffolk_rovers
Post #885592 15th Feb 2021 8:44am
Adammacky
Vinyl wrap? Short term solution and if you did prefer the panoramic glass it would be easy to go back Whistle
Post #885607 15th Feb 2021 10:21am
MichaelE
If only.........
I've just finished fitting pano windows. Well....nearly. Just got the edge sealing to do later today. I would have readily swapped my bodywork for yours. It was a pig getting the old windows out. I can't see you getting the pano windows off without a lot of destruction. Then there was the stress of fitting them, knowing that it's a one shot job. I had about 10 seconds to get them in the right position before they became immobile. So I taped metal guide strips in place to butt up against so that I got it right first time with no assistance. That glue set very firm and it's going nowhere.
Post #885680 15th Feb 2021 2:39pm
Linds Hanson
Guess it was a basic hardtop to start with, whoever cut those large openings was brave! There isnt much holds the outter skin to the top flange on the late sides (along the top of the cutout).
Post #885692 15th Feb 2021 4:13pm
landy andy
New panels bolt in and only require a new seal a long the bottom. Top seal is reused. I didn’t have pano windows, and wouldn’t as they look nasty, especially on anything but a black vehicle, but I swapped my rear panel on my 110 easily after getting them sprayed.
Before
During
After
Post #885734 15th Feb 2021 5:59pm
TomHutch
Cheers again fellas, and thanks for the pictures Andy! Think I’m gonna keep it as is for the moment then, I can use the money on some other upgrades Very Happy
Post #886248 18th Feb 2021 9:43am
Bev
Sensible choice keeping the funds for other upgrades or repairs.
When you consider the price and fitting of the panoramic glass, I would offer these up as a straight swap for panels from another truck. It really is a case of unbolting the old panels and bolting in the new panels. It would be best practice to change the bottom seals whilst your dismantling it.
In terms of cost - I reckon it’s at very least, cost neutral to yourself. In reality you should expect to make some money from your panels compared to standard as the glass is a reasonable expenditure to add.
With time on your side and the right person looking for panoramic glass it will all work out cost effective that way Thumbs Up 2002 Td5 | 90 County Station Wagon | Oslo Blue
Post #886274 18th Feb 2021 11:32am
landy andy
Agree. Getting a panel swap with someone who wants nasty glass sides should earn you some money, not cost you anything but a few hours of time.
Post #886357 18th Feb 2021 6:07pm
