![]() | Home > Maintenance & Modifications > Swapping out the panoramic windows |
Bev Member Since: 03 Apr 2013 Location: Perthshire Posts: 267 ![]() ![]() ![]() |
I think your going to need complete new or replacement side panels as
1. It looks like the hole is now enlarged for the panoramic windows so the originals won’t just slot straight in. 2. I understand those windows are bonded in to the panel so will be a nightmare to remove. I think your option one is easiest and would give the best results. You can buy a brand new replacement rear door for something like £240 from britpart OEM. Glass would be extra but plenty available on the resale market. Some photos of mine with the windows removed to painting. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge 2002 Td5 | 90 County Station Wagon | Oslo Blue 2006 Td5 | 90 County Station Wagon | Tonga Green (Gone ) 2002 Td5 | 90 County Station Wagon | Zambezi Silver (Gone) |
Defender SVX Member Since: 29 Jan 2009 Location: Co Durham Posts: 730 ![]() ![]() ![]() |
As above it’s looking like to do a good job you’re going to have to swap both panels and rear door, even if the openings hadn’t been enlarged by the time you’ve cleaned off the “
![]() ![]() If you remove the parts as a whole they have some value that will offset the replacements. I’d be interested in them and local to assist replacing ![]() ![]() Edit to add personally I think it looks spot on the way it is ![]() 16 Focus RS Nitrous Blue. 11 FFRR TDV8 Vouge SE Black Black. 08 DEFENDER SVX SOFT TOP (SUPERB) 08 DEFENDER 110 DCPU Stornoway grey (Overland Exploration Unit) 05 Fiesta ST 150 Van 04 Jaguar XKR 4.2 Supercharged V8 02 DEFENDER 90 TD5 (next years soft top project) 95 DEFENDER 110 CSW 300 TDi Phoenix black 95 DEFENDER 90 HT Monti Carlo blue COUNTY 300 TDi 67 109" SERIES 2a TUNED 200 TDI 64 DAVID BROWN 990 rat look 55 86" SERIES 1 |
Oakseywick Member Since: 20 Dec 2014 Location: Cirencester Posts: 1002 ![]() ![]() ![]() |
Member 2010blackdefender90 on here has done this he had the glass removed by a auto glass guy I think try and find his posts or it might be in his build thread if he has one. Andy
Defender 90 Defender 110 XS Cupra 290 |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4807 ![]() ![]() ![]() |
https://www.defender2.net/forum/topic63739...amic+glass
There you go. 2015 HT XS 90 2008 SVX 90 2000 XS TD5 90 |
TomHutch Member Since: 29 Nov 2020 Location: Sunderland Posts: 9 ![]() ![]() ![]() |
Thanks for the help guys. Looks like if I go for it it’ll be new panels and door then. Like you say seems more
Hassle than it’s worth trying to remove the glass. I’ll keep an eye out on here and the bay for any going up for sale. I’ve got some new wheels coming next week so gonna see how they look with the defender before changing anything out. Change my mind like the wind so I’ll probably end up liking it next week and keep it as is. But very useful info regardless, so thanks a lot fellas I really appreciate it. And thanks for the offer defender SVX, I’ll keep you posted ![]() |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7928 ![]() ![]() ![]() |
Welcome to D2N
![]() ![]() ![]() If you could find someone who wants the panoramic glass you could do a straight swap? James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
Adammacky Member Since: 28 Dec 2019 Location: West Midlands Posts: 309 ![]() ![]() |
Vinyl wrap? Short term solution and if you did prefer the panoramic glass it would be easy to go back
MichaelE Member Since: 18 Jan 2020 Location: Crawley West Sussex Posts: 155 ![]() ![]() |
If only.........
I've just finished fitting pano windows. Well....nearly. Just got the edge sealing to do later today. I would have readily swapped my bodywork for yours. It was a pig getting the old windows out. I can't see you getting the pano windows off without a lot of destruction. Then there was the stress of fitting them, knowing that it's a one shot job. I had about 10 seconds to get them in the right position before they became immobile. So I taped metal guide strips in place to butt up against so that I got it right first time with no assistance. That glue set very firm and it's going nowhere. |
Linds Hanson Member Since: 16 Jan 2021 Location: Cornwall Posts: 524 ![]() ![]() |
Guess it was a basic hardtop to start with, whoever cut those large openings was brave! There isnt much holds the outter skin to the top flange on the late sides (along the top of the cutout).
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5942 ![]() ![]() |
New panels bolt in and only require a new seal a long the bottom. Top seal is reused. I didn’t have pano windows, and wouldn’t as they look nasty, especially on anything but a black vehicle, but I swapped my rear panel on my 110 easily after getting them sprayed.
Before During After ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
Cheers again fellas, and thanks for the pictures Andy! Think I’m gonna keep it as is for the moment then, I can use the money on some other upgrades
Sensible choice keeping the funds for other upgrades or repairs.
When you consider the price and fitting of the panoramic glass, I would offer these up as a straight swap for panels from another truck. It really is a case of unbolting the old panels and bolting in the new panels. It would be best practice to change the bottom seals whilst your dismantling it. In terms of cost - I reckon it’s at very least, cost neutral to yourself. In reality you should expect to make some money from your panels compared to standard as the glass is a reasonable expenditure to add. With time on your side and the right person looking for panoramic glass it will all work out cost effective that way ![]() 2006 Td5 | 90 County Station Wagon | Tonga Green (Gone ) 2002 Td5 | 90 County Station Wagon | Zambezi Silver (Gone) |
Agree. Getting a panel swap with someone who wants nasty glass sides should earn you some money, not cost you anything but a few hours of time.
