Home > Td5 > knock in steering column over rough roads
paullo
Canada
I've just had a bunch of work done on my 90; and this weekend was the first time we were able to take it out and put any significant mileage on it- I've noticed a knocking noise from what feels like the steering column whenever we're driving over rough or bumpy roads. I'm nearly certain it wasn't there before. Can anyone point me in the right direction on where to have a look first or what might be an obvious culprit (to someone who's not very mechanically inclined)?
Post #88525 11th Sep 2011 12:52pm
wslr
Open the bonnet and get a mate to turn the steering wheel left and right without the engine running. Doesn't need to be big movements, just small.
While they do that, check the steering system for anything that it shouldn't be doing. Even if it happens only while driving on the rough, there should be some clue.
Post #88537 11th Sep 2011 3:05pm
Landy nut
United Kingdom 2006 Defender 90 Td5 PU Epsom Green
Drop arm ball joint will probably be the culprit. Just make sure you get a decent one (I always buy genuine) and get whoever replaces it to replace ALL the parts and not just the ball itself as the cup at the bottom is what wears the most.
Post #88551 11th Sep 2011 4:22pm
paullo
Canada
Cheers for the responses Very Happy
I'll have a look this weekend and go from there.
Thanks.
Post #88881 13th Sep 2011 2:13pm
