Home > Expedition & Overland > Henri the 110 goes pop top!
Page 12 of 17 <123 ... 111213 ... 151617>
Timcat
United Kingdom 2012 Defender 110 Puma 2.2 SW Indus Silver
To be honest I nearly took the cover off completely as the tank will protect the u/s of the battery box. Looks like a Safari Equipment tank is it? For a 90 / 130 maybe..
Post #884313 10th Feb 2021 7:58am
When you say cover, do you mean the plastic thing in the photo on the previous page?
I've never been sure what the purpose of this thing is (and the corresponding one on the other side), nor even which vehicles have them. I suspect that they are intended as insulation or sound-proofing and maybe were fitted to XS models only, certainly my County-spec DCPU never had them. They seem pointless to me, and presumably trap mud and damp.
I'd be fascinated to learn if there is any benefit to having them.
Post #884337 10th Feb 2021 10:00am
wyvern
United Kingdom 2012 Defender 110 Puma 2.2 XS CSW Firenze Red
Looking really good Tim!
What is the working capacity of the water tank ?
I’ll be picking your brains later for fitting tips!
(just have to save up first!)
Thumbs Up Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Elgar -TDCI(Puma) 110XS Dormobile - now sold
Devon & Cornwall 4x4 Response - DC126
Post #884371 10th Feb 2021 11:51am
Timcat
Most people I know with them remove them as they fill up with dirt & promote rot if used a lot off road.
Post #884488 10th Feb 2021 6:14pm
Timcat
Thumbs Up
Hi Gary, both fuel tanks for us giving us 850 mile range. The sill tank is 56L, we went for a canister water system as it’s easier to clean & more flexible.
Post #884490 10th Feb 2021 6:17pm
Timcat
Main tank fitted, changed the rear lines & let it bleed itself. Started first turn..
Post #885072 12th Feb 2021 8:37pm
yobbie
United Kingdom 1999 Defender 90 Td5 Heritage LE Bronze Green
yobbie wrote:
I modified the tank so it would mount higher without cutting the battery box
Yes this is a 90 tank, I cut the top of the tank and welded in the two boxes so that it would go directly underneath the battery box as there are two boxes sticking out underneath the battery box.
I also made a ‘Y’ piece at the fuel filler to fill both tanks (main original and aux under drivers side) so I didn’t have to cut another fuel filler
I use the tank under the battery box as water and I fill from the rear quarter
Post #885531 14th Feb 2021 6:52pm
Timcat
Nice work, wanted separate filling points so it’s a separate system incase we get contaminated fuel. Empty the main & then pump the sill tank into the main.
Post #885545 14th Feb 2021 7:43pm
Timcat
Finally! Zero off set wheels have arrived.
Post #889052 4th Mar 2021 6:26pm
Timcat
Post #889054 4th Mar 2021 6:28pm
L110CDL
They are looking good on Henri Thumbs Up Clayton.
Keeper.
Post #889323 5th Mar 2021 9:46pm
Timcat
Big day today with the suspension turning up.
Post #890594 10th Mar 2021 10:35pm
JOW240725
Looking good! Thumbs Up James
Instagram @suffolk_rovers
Post #890596 10th Mar 2021 10:50pm
Timcat
Yesterday was a full on day...
Post #891369 14th Mar 2021 4:37pm
Timcat
Before & after....
Post #891370 14th Mar 2021 4:39pm
