![]() | Home > General & Technical (L663) > Raised Air Intake (RAI) Install ~ without removing the door |
There's a couple of communications on this part.
Aftersales Bulletin - Raised Air Intake Fasteners Missing 3rd September 2020 ![]() Click image to enlarge 2nd to follow... |
DSL Member Since: 20 Aug 2007 Location: Wandering the wasteland. Posts: 837 ![]() ![]() |
That car looks so much better with black A pillar trim, and looks a reasonably easy swap even for a non-techie like me.
![]() PS Looks to my inexperienced eye, well my AT searches, they the 110s have body coloured A pillar external trims, while 90s are black. ![]() ![]() |
SSM 74888 - Fixing Torques Too High for Raised Air Intake
![]() Click image to enlarge ![]() ![]() Click image to enlarge |
Q86ARR Member Since: 28 Feb 2017 Location: Earth Posts: 44 ![]() |
Land Rover give 1.1 hours to fit the raised air intake
The door only has three bolts and one connector holding it on Just take the door off and do it properly! |
shawnpalmer Member Since: 29 Sep 2020 Location: Cumming Posts: 28 ![]() ![]() ![]() |
The door removal is actually very easy, especially with two ppl to lift off and back on.
I've no idea how large the ducting is behind the wing-side grille, but won't that massively reduce the amount of air going in? I appreciate that the laws of aerodynamics means wind will peel round the back of the RAI, but it's doing a turn of almost 180 degrees. At speed. I wonder what loss of air that gives, incrementally with speed? Monsieur Le Grenadier
I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3711 ![]() ![]() ![]() |
The grill has fallen off my RAI, twas only held on with what looks like double sided paper based sticky back tape. I now have a piece of one sided sticky back paper stuck to each part
Julep Member Since: 07 Nov 2020 Location: Jersey Posts: 25 ![]() ![]() |
I have just lost my grill too. Lucky it dropped off when only at low speed and not when flying down the motorway. Just waiting to hear what the dealer will do. Either stick it back on or replace.
![]() Click image to enlarge ![]() Click image to enlarge With grill off though you can really see how cheap it is with rough plastic edges... ![]() Freelander Sport Td4 Discovery 4 XS TDV6 Defender X 110 P400 |
gypsykali Member Since: 05 Oct 2021 Location: Bestcoast Posts: 1 ![]() ![]() |
Is the aftermarket RAI worth it? $350 shipped~
https://www.lrparts.net/vplep0435-raised-a...rover.html |
