![]() | Home > Maintenance & Modifications > DCPU Spare Wheel Carrier |
Avelingporter Member Since: 25 Jan 2016 Location: Southampton Posts: 409 ![]() ![]() ![]() |
My friend has a Safari Equip one on his dcpu. In fact this is his second as he also had one on his old truck. Try them.
Are you looking for a DCPU spare wheel carrier as in internal to the tub or just an external spare wheel carrier to be hung off the rear crossmember?
Disco_Mikey Member Since: 16 Nov 2014 Location: Dundee Posts: 532 ![]() ![]() ![]() |
Normal pick up
![]() ![]() Click image to enlarge |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6052 ![]() ![]() |
Get the best one.
https://www.4x4overlander.com/product/naka...ckups-bpc/ |
Or if you don’t think you Landy is worth it
https://www.4x4overlander.com/product/whee...-tailgate/ Both apparently in stock. |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2239 ![]() ![]() ![]() |
Naka is ridiculous money frankly.
The Saf equipe I had issues with it swinging open after loosening the antiluce connectors So for more than 75% less than the Naka I fit a side open tailgate with some custom made heavy duty hinges. Spare now sits on the door as per a normal Def. ![]() Click image to enlarge ![]() Click image to enlarge |
So are you looking for this? ![]() Click image to enlarge |
Apologies. One that bolts onto the crossmember
Have spoke to Brendan about it ![]() |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18031 ![]() ![]() ![]() |
One of the reasons that these are hard to find is that there are very, very few that are designed to work with a tailgate rather than a rear door. I only know fo two, the Nakatanenga offering, and the Allisport offering, both of which are rather pricey. If you want one that fits to the crossmember and will work without modification with an Ifor Williams canopy, the number drops even further, to zero. Both of the above will foul the rear flap of the canopy and prevent it from opening, although it isn't hard to modify the Allisport one so that it works. My Allisport carrier was let down by the shocking quality of the powder-coat, but to be fair it was an early one when they were still Sonic3D carriers, not Allisport, so the coating may be better now (it could hardly be worse).
It is about time that someone offered a crossmember mounted swing away carrier for pickups that doesnt foul the rear flap, doesn't foul the towing hitch, and doesn't rust. It wouldn't be difficult. Last edited by blackwolf on 7th Feb 2021 7:13pm. Edited 1 time in total |
steve E Member Since: 06 Mar 2011 Location: Tenby Posts: 2076 ![]() ![]() |
Sorry to ask but does Anyone have the plastic spare wheel securing bolt they would like to sell.
I can’t find the part online and my spare sits on the tub floor. |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2363 ![]() ![]() ![]() |
I understand ORE are developing their carrier to suit the DCPU https://www.ore4x4.co.uk/product-page/ore-...rier-black > 110 XS Double Cab
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 ![]() ![]() ![]() |
The exact reason I now have the safari equip wheel carrier. Also many holes in the rear tub so I’m now committed. I did think about having the ifor canopy hinge at the bottom as you lifted it to clear the spare wheel but it seemed like a lot of faff. Although now I’m looking at re coating the carrier (and sliders, also safari equip) as the powder coat has flakes off in many places. Relieving the galv undercoat. So it won’t rust. Just looks ![]() Instagram - @r22oyp Roy |
Plastic? Mine secured with a threaded bar attached to the bulkhead. Had a metal disc with foam on it and a wing nut. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html Instagram - @r22oyp Roy |
Thanks Roy
I have the threaded bolt from the bulkhead but not the fixing bit to hold the spare in place 👍 |
