| Steve_overland Member Since: 14 Oct 2018 Location: Gaydon Posts: 294
Bit of fabrication work to make my fuse box cover fit with the type of switches Iām using .... oh and a curry hook....
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge @steve_overland on Insta. 110 expedition vehicle with pop roof |
| Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4808
Nice tidy install ^^^^ 2015 HT XS 90
2008 SVX 90 2000 XS TD5 90 |
Dropped the defender into my local amazing Indie (Vanstones of Launceston) to have the rear chequerplate on the crossmember removed and the cross member resprayed ready for the next project
Good to see the rear crossmember in such great condition after 4.5 years under the chequerplate. I did make sure the crossmember was well treated prior to fitting the chequerplate and lots of ACF 50 applied during that time too. Click image to enlarge Click image to enlarge 2008 SVX 90 2000 XS TD5 90 |
| L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11091
Will look nice with the paint on, Simon
| battle-defender Member Since: 17 Dec 2020 Location: Battle Posts: 22
Click image to enlarge Checking setting out dimensions for the feet and noticed the length is not as advertised. Flatdog claim it is 2.8m long. The one delivered is 75mm shorter, which is disappointing as it would look better on the truck if it aligned with the front windscreen and the rear panel. Quite fiddly to attach the leg feet clamp as there is insufficient space to get a ratchet spanner on to the nut. Defender 110 XS SW Puma - 2011 Defender 110 XS SW - 56 |
| Matt110 Member Since: 29 Jun 2014 Location: UK Posts: 688
Most manufacturers seem to claim 2.8m long but the length is then tuned to follow the rake of the screen not the actual length of the rack....
Safety devices do the same with their per mine below. Click image to enlarge |
Thanks Matt110,
This clarifies, but does not help make the roofrack 2.8m. I emailed Flatdog, awaiting their response. Defender 110 XS SW Puma - 2011 Defender 110 XS SW - 56 |
| Supacat Member Since: 16 Oct 2012 Location: West Yorkshire Posts: 11018
Off to measure my Patriot...
| rockster57 Member Since: 15 Nov 2014 Location: West Yorkshire Posts: 945
Holding the indicator stalk on for RH manoeuvres has become wearisome. Hence a delivery van turned up today with this:-
Never seen one in a red box before, could you let us know how you get on with it, if it cures the problem totally many thanks Clayton. 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
| JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7946
The Puma is at the spa for some well overdue pampering...
Click image to enlarge Click image to enlarge So I got old red out and promptly stuck in the snow Click image to enlarge James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
| MussEd Member Since: 20 Feb 2013 Location: East Lothian Posts: 376
Got the grease gun out for some routine maintenance - spare wheel carrier got some attention and the squeaky brake pedal. Mundane but satisfying.
Less mundane was taking a phone call from a local specialist in response for a quote for a new clutch and output shaft š³š³š³ |
| Ashbyandy Member Since: 17 Dec 2015 Location: Leicestershire Posts: 228
Fitted Polybushes (orange dynamic), to 110 today. Every bush except front shocks, and A frame. What an improvement, well pleased, šš.
Ashbyandy |
