Home > Technical > 2005 defender 90 TD5 diagnostic port reader
farish3000
United Kingdom 2005 Defender 90 Td5 HT Aintree Green
Hi there could do with some advise
I have a 2005 defender 90 TD5 I have plugged a reader into the diagnostic port which does power the reader so it's not a connection port issue. But it fails to read anything on scan like it can't understand it. But I works on my son's 2004 landrover
Does anyone know if the 2005 90 is ODB2 compliant?
Or what diagnostic reader I could use?
Thanks cheers guys
Post #882080 31st Jan 2021 12:21am
ibexman
Nanocom evolution
Post #882081 31st Jan 2021 12:26am
landy andy
Post #882082 31st Jan 2021 12:34am
farish3000
Thanks, for the info looks like I would need a NCOM01 for TD5 engined models £280.
Anyone aware of any cheep ones as I'm only wanting to view any present errors
Post #882083 31st Jan 2021 1:01am
grafty99
Yeah, td5 isn't fully OBDII compliant. You can use an android device and free Td5 app Thumbs Up
This is the one I use
https://drive.google.com/drive/mobile/fold...DWV-PdLNDI
If its a basic spec vehicle you'll likely get ABS, AC and tacho drive errors justso you know Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #882084 31st Jan 2021 1:05am
farish3000
Nice one, I'm on Android. How do I do this?
Post #882085 31st Jan 2021 1:07am
farish3000
https://github.com/hairyone/TD5Tester
Do you know where I can download that Td5 tester can't find it in the app store
Also a VAG COM KKL usb -> OBD2 cable that uses an FTDI chip.
Post #882087 31st Jan 2021 1:46am
grafty99
It's not in the app store, you need to download from github link I posted and install it directly to your device (allow 3rd party apps in settings if not already) Thumbs Up
Edit: changed link to direct Google drive link - install the appropriate APK file from that. As for a comm cable I already had one that worked so can't say where to get one I'm afraid Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #882121 31st Jan 2021 10:18am
farish3000
Thanks I just tried the Google drive link but says the page is empty
404. That’s an error.
The requested URL was not found on this server. That’s all we know.
Post #882212 31st Jan 2021 6:48pm
grafty99
Strange, it worked when I posted it - I checked! Might be worth trying again later Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #882220 31st Jan 2021 7:16pm
farish3000
Will do you might need to make the folder public
Post #882227 31st Jan 2021 7:43pm
grafty99
It's not my drive, it's the drive I downloaded my APK from Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #882231 31st Jan 2021 7:56pm
farish3000
Ive downloaded the file as a zip on my android tablet but can't unzip. There doesn't seem to be any instructions on how to install and run
Post #882491 1st Feb 2021 11:17pm
farish3000
I've unzipped the files now how do I run/install the application
Post #882493 1st Feb 2021 11:30pm
