![]() | Home > Technical > 2005 defender 90 TD5 diagnostic port reader |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2963 ![]() ![]() |
Nanocom evolution
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5971 ![]() ![]() |
Get in quick whilst you can.
https://www.defender2.net/forum/topic65975.html |
farish3000 Member Since: 31 Jan 2021 Location: Cumbria Posts: 8 ![]() ![]() ![]() |
Thanks, for the info looks like I would need a NCOM01 for TD5 engined models £280.
Anyone aware of any cheep ones as I'm only wanting to view any present errors |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
Yeah, td5 isn't fully OBDII compliant. You can use an android device and free Td5 app
![]() This is the one I use https://drive.google.com/drive/mobile/fold...DWV-PdLNDI If its a basic spec vehicle you'll likely get ABS, AC and tacho drive errors justso you know ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton Last edited by grafty99 on 31st Jan 2021 10:22am. Edited 2 times in total |
Nice one, I'm on Android. How do I do this?
Do you know where I can download that Td5 tester can't find it in the app store Also a VAG COM KKL usb -> OBD2 cable that uses an FTDI chip. |
It's not in the app store, you need to download from github link I posted and install it directly to your device (allow 3rd party apps in settings if not already)
![]() Edit: changed link to direct Google drive link - install the appropriate APK file from that. As for a comm cable I already had one that worked so can't say where to get one I'm afraid ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Thanks I just tried the Google drive link but says the page is empty
404. That’s an error. The requested URL was not found on this server. That’s all we know. |
Strange, it worked when I posted it - I checked! Might be worth trying again later
Will do you might need to make the folder public
It's not my drive, it's the drive I downloaded my APK from
Ive downloaded the file as a zip on my android tablet but can't unzip. There doesn't seem to be any instructions on how to install and run
I've unzipped the files now how do I run/install the application
