Home > Puma (Tdci) > paranoid about factory fill oils
Page 2 of 2 <12
Small Clanger
JSG wrote:
Small Clanger wrote:
Bought a front bumper from Duckworth Parts which arrived on Wednesday. Cut some 35mm holes in it for a pair of recovery swivels ( Flatdog 4x4, ordered at 15:05, arrived next day 08:30) and drilled some holes for spotlights ( IPF from 4x4AT.com) and then took it over to Jacksons in Yeadon to have it powder coated gloss black.
I assume you know that a standard bumper (if that is what you have) will need a lot of reinforcing to use recovery points?
It is a standard front bumper and I've cut the swivels in just in front of the chassis rails at what I figured would be the strongest point. But, as I say in the above post, I'm not planning on using them for dragging vehicles out of swamps. Mainly for work i.e. pulling large cable runs around building sites and farmyards.
Please see my gallery. Now to try fathom out how to insert photo's into posts Confused
Cheers. Smile
Post #85361 20th Aug 2011 2:22pm
MD5
2009 Defender 110 Puma 2.4 SW Alpine White
Today I replaced the transfer oil.
Everything went fine, very few metal dust attached to the drain plug magnet.
Next week I will change the transmission oil. Is the drain plug also magnetic ?
Post #87457 3rd Sep 2011 8:21pm
rossy
yes it is - and I'll bet there will be plenty of metallic gunge stuck to it - more than on the Tbox plug anyway !
Post #87462 3rd Sep 2011 8:40pm
MK
I`m not sure it is. At least the MY07 it is not. Puma 110" SW
Post #87465 3rd Sep 2011 9:01pm
mse
Diffs Magnetic yes, Transfer box no...you can buy a magnetic one Mike
Post #87477 3rd Sep 2011 9:41pm
rossy
MY11 gearbox drain plug is magnetic - well it is on mine anyway. There was quite a mound of tiny metal shards stuck to it when I changed the oil a couple of weeks ago - like a little sculpture it was Laughing
Post #87483 3rd Sep 2011 10:11pm
mse
Gearbox is as is the diffs, just not the Transfer box Mike
Post #87494 3rd Sep 2011 10:37pm
Carl l
Glynparry25 wrote:
spudfan wrote:
Hope that is not Glynn Parry's sheep you are using. He won't be too happy if it is. Rolling with laughter
There was me thinking Baarbra was a one man sheep Rolling Eyes
Confused
One sheep man? Current: 2011 Shogun SWB 3.2td 200hp stock, Auto (my knees are shot), but this is a great farm truck
Prev: a Disco (got old), a Range Rover (too ostentatious) and a Defender (knees).
Tractor: 1993 Ford 8830, 6.6td, 180hp at PTO stock
Post #88053 7th Sep 2011 3:45pm
MD5
I found this plug that I believe is the MT82 fill plug. Is the same type and size of the drain plug.
The image was taken looking front to rear.
Is this the right plug ? I read somewhere that the fill plug is different from the drain plug.
Anyway, I flushed about 2.7 liters of oil, I'm now waiting your answer about the fill plug.
Post #88177 8th Sep 2011 7:17am
MK
That`s the one and both are the same. Puma 110" SW
Post #88200 8th Sep 2011 10:02am
MD5
Thanks for the information! I replaced both transmission and gear oil.
Next week I will install magnetic plugs in the front and rear diffs.
Post #88386 10th Sep 2011 5:17am
Page 2 of 2 <12
