![]() | Home > Puma (Tdci) > paranoid about factory fill oils |
MD5 Member Since: 02 May 2011 Location: Italy Posts: 143 ![]() ![]() |
Today I replaced the transfer oil.
Everything went fine, very few metal dust attached to the drain plug magnet. Next week I will change the transmission oil. Is the drain plug also magnetic ? |
rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1296 ![]() ![]() ![]() |
yes it is - and I'll bet there will be plenty of metallic gunge stuck to it - more than on the Tbox plug anyway !
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2478 ![]() ![]() ![]() |
I`m not sure it is. At least the MY07 it is not. Puma 110" SW
mse Member Since: 06 Apr 2008 Location: UK Posts: 5108 ![]() ![]() ![]() |
Diffs Magnetic yes, Transfer box no...you can buy a magnetic one Mike
MY11 gearbox drain plug is magnetic - well it is on mine anyway. There was quite a mound of tiny metal shards stuck to it when I changed the oil a couple of weeks ago - like a little sculpture it was
Gearbox is as is the diffs, just not the Transfer box Mike |
Carl l Member Since: 03 Sep 2011 Location: Northern Hemisphere Posts: 9 ![]() |
![]() One sheep man? Current: 2011 Shogun SWB 3.2td 200hp stock, Auto (my knees are shot), but this is a great farm truck Prev: a Disco (got old), a Range Rover (too ostentatious) and a Defender (knees). Tractor: 1993 Ford 8830, 6.6td, 180hp at PTO stock |
I found this plug that I believe is the MT82 fill plug. Is the same type and size of the drain plug.
![]() Click image to enlarge The image was taken looking front to rear. Is this the right plug ? I read somewhere that the fill plug is different from the drain plug. Anyway, I flushed about 2.7 liters of oil, I'm now waiting your answer about the fill plug. |
That`s the one and both are the same. Puma 110" SW
Thanks for the information! I replaced both transmission and gear oil.
Next week I will install magnetic plugs in the front and rear diffs. |
