![]() | Home > In Car Electronics > Dim/dip relays on 300TDi |
jeffersj Member Since: 23 Jan 2015 Location: Near Preston Posts: 431 ![]() ![]() ![]() |
I know that this subject has been covered a lot but can I just replace the pink dim/dip relay YWC 10050 with the later bypass unit YWZ10003 to avoid main switch burning ourt so often? Jeff
Ex 1968 Series 2A Ex 90 TD5 Ex D3 Ex D4 |
Yes, but that's not really the cause of the switch burning out. Alternatively, just unplug the resistor under the wing to disable the system. Darren
Thanks LRA, i think water had got at the relay probably shorting it. if I just unplug the relay are the loose wires/plug OK just left? Jeff
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2243 ![]() ![]() ![]() |
The headlights won't function correctly if you unplug the pink relay, you would need the bypass unit (or a wire with two spade terminals). You can however just unplug the resistor on the inner wing without any further action.
Steve 02' 110 TD5 Double Cab Rebuild Thread |
