Home > In Car Electronics > Dim/dip relays on 300TDi |
jeffersj Member Since: 23 Jan 2015 Location: Near Preston Posts: 431 |
I know that this subject has been covered a lot but can I just replace the pink dim/dip relay YWC 10050 with the later bypass unit YWZ10003 to avoid main switch burning ourt so often? Jeff
Ex 1968 Series 2A Ex 90 TD5 Ex D3 Ex D4 |
28th Jan 2021 2:18pm |
Yes, but that's not really the cause of the switch burning out. Alternatively, just unplug the resistor under the wing to disable the system. Darren
28th Jan 2021 2:34pm |
Thanks LRA, i think water had got at the relay probably shorting it. if I just unplug the relay are the loose wires/plug OK just left? Jeff
28th Jan 2021 3:04pm |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2200 |
The headlights won't function correctly if you unplug the pink relay, you would need the bypass unit (or a wire with two spade terminals). You can however just unplug the resistor on the inner wing without any further action.
Steve 02' 110 TD5 Double Cab Rebuild Thread 84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale |
28th Jan 2021 3:24pm |
