Home > Orders 2021MY (L663) > MY21 19" wheel - brake size versus 20"?
AusL663
Australia
Hey everyone
I'm going to place an order for a D300 SE shortly and found something in the MY21 technical specs. It shows 19" wheels as running 363/350mm f/r brakes while 20" runs 380/365. From this running 18" tuffants alloys might work if I order factory 19" option wheels?
Can anyone confirm if they do change the brake size between 19 and 20 inch wheels, the only reference ive found is from the tech spec at https://media.landrover.com/en/tech-specs, be great it's correct but a huge mistake if I got stuck on 19's!
Thanks
Post #880701 25th Jan 2021 6:03am
Simon Audi
In the UK - You can only specify the 19" 20" or 22" on D300
As standard it comes with 363mm Disc and 4 Pot caliper on front and 350mm single caliper on rear.
I would not plan on being able to fit 18" wheels - unless you plan to modify brakes.
The standard on D200 or D250 is 349mm discs - twin sliding calipers at Front and 325mm single caliper at rear.
Post #880703 25th Jan 2021 6:42am
AusL663
Australia
Sorry what I was asking is are the brakes the same between 19 and 20 inch rims, the tech spec seems to say they aren't?
Post #880738 25th Jan 2021 10:39am
Simon Audi
And what I showed you was the brakes are based on the Engine
Powerful faster engines have the bigger brakes.
With those powerful engines and bigger brakes you can not specify the 18" wheel
The Powerful Engine can be specified with 19" wheel, 20" or 22" - NO 18"
Post #880739 25th Jan 2021 10:48am
Digger2000
United Kingdom 2006 Defender 90 Other HT Tonga Green
If you spec 22” Wheels then they change the break callipers to 6 piston and smallest wheels size are 20” that can fit.
Post #880750 25th Jan 2021 11:29am
