Home > Maintenance & Modifications > Optimill QR steering boss - advice please!
Page 4 of 6 <123456>
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
nitram17 wrote:
Anybody used the moto lita version of the optimill boss?
I had the Optimil boss and lock but before they did a Mota lita version but supplied an adaptor to convert it.
Been fine and I’m really pleased with it, had the lock updated to the later anti pick type by then.
Kind Regards
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88ā€ 2A 200tdi
2002 110 Hardtop
Post #880100 22nd Jan 2021 11:54am
Steve_overland
United Kingdom 1997 Defender 110 300 Tdi HT Chawton White
Steve_overland wrote:
Will go back and look for pins... šŸ™ˆ thanks all
All sorted nice and simple... wish i had done it in the first place hahahah @steve_overland on Insta.
110 expedition vehicle with pop roof
Post #880333 23rd Jan 2021 4:10pm
nitram17
Shorty53 wrote:
Nitram17, yes I have successfully fitted a Motolita steering wheel with the Optimill adapter and Q/R steering boss.
if you dont mind...could you measure the depth of the boss to the steering wheel?and post on here !thanks i n advance!I like the 15inch wheel and i dont think mono do one.
Post #880367 23rd Jan 2021 7:25pm
Shorty53
United Kingdom 2012 Defender 90 Puma 2.2 XS CSW Santorini Black
Photographs show Moto-Lita 15" wheel with Optimill Q/R boss and Moto-Lita adapter
Post #880694 25th Jan 2021 12:46am
Shorty53
Duplicated a photograph! Correct photo added.
Post #880695 25th Jan 2021 12:49am
nitram17
Thanks shorty 53 thats a nice steering wheel is it 14 or 15 inch ..did you get it from mud uk?
Post #881197 26th Jan 2021 11:50pm
Shorty53
Yes, 15" from MUD UK.
Post #881200 27th Jan 2021 12:10am
nitram17
I thought it might be ..I like it a lot ..pity its sold out in black! I take it that there is no play in the boss?
Post #881206 27th Jan 2021 12:37am
Shorty53
No, quite a positive fit with the locator pins. You would'nt think it was removable.
Post #881209 27th Jan 2021 12:43am
nitram17
blackwolf wrote:
I use both versions (I have a "posh" wheel and a wheel for use if doing grubby jobs or taking the vehicle for the MoT etc).
Apart from the alignment of the holes they are identical and of equal high quality.
Sorry Blackwell im confused ..do you have a moto lita wheel with a optomiil moto lita top bit of the boss fitted and a momo version that are interchangeable with the bottom part of the boss?sorry but i turned sixty in october and im losing thousands of brain cells by the minute Big Cry
Post #881212 27th Jan 2021 12:56am
After checking the Optimill page I realise that I have made an error.
One of my wheels needs a Startech (note, not Moto-Lita) style boss, the other a Momo style boss. These two bosses only differ in their hole pattern for the wheel.
It is only the steering wheel part of the boss which differs, the steering column part of the boss is common to either wheel fitment.
Looking at the pictures, I think the same is true for the much larger Moto-Lita boss, and again I would expect the part that fits to the column to be the same in all three cases, with just the wheel part differing.
The staff at Optimill are exceptionally helpful and friendly, so if it is important give them a call, I am sure they'd give you the definitive answer.
Edit, my coffee has now kicked in and the brain has lurched into life. The column part of all the bosses must be the same, since the locking cap fits any of them. So Optimill Moto-lita, Momo, and Startech steering wheel hubs should fit any Optimill boss, whether 36 or 48 spline. A truly modular system.
Post #881246 27th Jan 2021 10:02am
nitram17
I will give optomil a ring as the lock might fit all of them but the holes and pins might be in different positions which may make the steering wheel of century if you interchange them and it would not matter for the spinning lock.i know my present snapoff is made with a variation in the fitting holes and pin positions...and I think optomil allegedly borrowed from twisted to make their all in one QR Boss.
Post #881319 27th Jan 2021 3:23pm
I am very sure that the pinning is the same on all Optimill bosses. Optimill wisely chose to provide the security by means of the locking cap rather than unique pinning, which has the huge advantage that a villain can't simply remove the boss from the column, and the boss is also cheaper to manufacture (since the machining is the same for all).
You may be unaware that the locking boss fits onto the hub pins, so if the pinning was different then a different cap would be needed for each pinning configuration.
Post #881333 27th Jan 2021 5:02pm
The lock engages with the pins so it's definitely the same on all.
 Darren
Post #881337 27th Jan 2021 5:22pm
nitram17
Thanks blackwollf you have made it very clear for me!
Post #881345 27th Jan 2021 5:54pm
