|  | Home > Puma (Tdci) > Idling surges |
| Landyrover Member Since: 04 Jul 2011 Location: Northampton Posts: 33      | Could this be an injector problem?? "You know, Marge, mud is nothing more than wet dirt!" (Homer Simpson) | ||
|  4th Sep 2011 1:42pm |
| Allan Member Since: 09 Sep 2009 Location: Perth Posts: 166      | Mine only does it cold, starts ok and idles but when rpm run between 800 and 1200 feels almost like half a cyl missing. Also smoke. When it warms all good. Cold here at the moment (mid winter) 8 dec cel. In on Thursday to find out why. Will post if they fix It.
 Allan | ||
|  5th Sep 2011 3:10pm |
| jasonshum Member Since: 10 Jun 2011 Location: Hong Kong Posts: 13    | this..??
|  5th Sep 2011 5:52pm |
| dgardel Member Since: 30 Nov 2008 Location: Veneto (Heart & Head) Posts: 3586    | EGR related also......
 Try to disconect the EGR connector Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition   IID Pro MV License | ||
|  5th Sep 2011 6:06pm |
| MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2512      | ^^^^^^^^ Most problably. My EGR was properly shut down and no more idle issues. Puma 110" SW
 ............................................................. Earth first. Other planets later | ||
|  5th Sep 2011 7:00pm |
| Allan Member Since: 09 Sep 2009 Location: Perth Posts: 166      | Mine does the miss like thing only when cold and when throttle used very lighyly at very low rpm. EGR was replaced last month, not that that means anything.
 Allan | ||
|  5th Sep 2011 11:16pm |
 Where is this please? Cheers "You know, Marge, mud is nothing more than wet dirt!" (Homer Simpson) | ||
|  6th Sep 2011 6:27pm |
 That's it, but settled after 10-15 seconds. Did you fix this? "You know, Marge, mud is nothing more than wet dirt!" (Homer Simpson) | ||
|  6th Sep 2011 6:29pm |
| rev it Member Since: 25 Jul 2011 Location: Kent Posts: 6      | Hello, About two weeks ago, I had the fuel metering valve fitted. So far I have had no odd surging (fingers crossed) since. | ||
|  6th Sep 2011 8:08pm |
| Landyrover Member Since: 04 Jul 2011 Location: Northampton Posts: 33      | Good news!   "You know, Marge, mud is nothing more than wet dirt!" (Homer Simpson) | ||
|  6th Sep 2011 9:15pm |
| Allan Member Since: 09 Sep 2009 Location: Perth Posts: 166      | Took mine in today to sort. Will report when they return it. I also have a caster issue, slight pull left that i want fixed, doesn't annoy around the city but on long trips its a pain.
 Allan | ||
|  7th Sep 2011 1:48pm |
 Not Yan~~Too Bad~~~ | ||
|  7th Sep 2011 5:01pm |
 fuel metering valve fitted?Change This is ok..?h | ||
|  7th Sep 2011 5:22pm |
| Landyrover Member Since: 04 Jul 2011 Location: Northampton Posts: 33      | Garage diagnosed sticking EGR valve. No fault codes generated but they say noise made when it goes through the self-cleaning routine when the engine is turned off is excessive.
 Nick "You know, Marge, mud is nothing more than wet dirt!" (Homer Simpson) | ||
|  8th Sep 2011 7:06pm |
| Posting Rules
